When I edit an existing resource (I change only it’s name) and then save it, after the “weak password” notification is closed, the “edit resource” window will stay there forever with an rotating circle on the “save” button. I can only get rid of it when I reload the page, and then the change has not been saved.
I can create new resources and I am able to edit those. The issue is only with existing resources.
Last changes on my installation: update to v5.1.0, created metadata key, use shared metadata key.
We’re not able to reproduce this issue, and would appreciate your help to get additional information.
Can you tell us which operating system you are running ?
The version of the API?
The browser (Chrome/Firefox/Edge) you are using and its version?
The version of the extension?
What would be also useful is the logs from the client application.
UI application logs
Go to your passbolt API url, right click > inspect, go to the Console tab
Service worker logs
Chrome: Go to chrome://extension, click on passbolt > details button, enable developer mode in top right corner, then click on inspect view > service worker.
Firefox: Go to about:addons, click on the COG on the top right > debug addon, then click on Inspect
After playing with the Metadata settings which are marked as “beta” the problem has been resolved. I’m sorry I can’t tell exactly which setting finally resolved the issue, as I don’t want to break my production system (again). Maybe you have a Passbolt instance for testing.
