Unable to set offline in CE
Hello everybody, I just upgraded my CE installation on Docker to 5.17 and I’m still unable to get the offline feature working: I simply turned it on in the settings and thought I should’ve seen the option in the drop down menu, but nothing appears yet. I tried top-level unshared entries as well as folder-included and shared ones without success.
Am I missing something?
TIA
Stefano
Hello @stefano.d Thank you for the feedback. If you’ve turned the settings on then you should see the option in drop down menu in that account. Can you confirm if you
  1. have selected a single resource’s menu options
  2. and it is a V5 resource: a password, TOTP or pin code
Optionally you can enable column “Available Offline” in the resource workspace that will let you know which of your resources support that option.
Hello @sowmya and thanks for your reply. The following screenshots depict the situation I’m having with a resource I just created (in order to avoid doubts about V5), as you can see there’s no reference to “Offline”:
Thanks,
Stefano.
As we can see in the “Available Offline” column, offline availability is not an option for that particular resource.
This could be because, either the resource is not among the currently offline supported resource types: Passwords, TOTPs and Pin codes; or it is a V4 resource (no encrypted metadata - For more information on creating V5 resources please checkout https://www.passbolt.com/docs/admin/resource-types/encrypted-metadata/ )
Oh yes. Actually it’s not an option for any item in the list, and here are my settings for metadata encryption:
BTW the item in the previous post is a password.
@stefano.d As you see the “Getting Started” page, you might not have enabled encrypted metadata (hence V5 resource creation) on your instance yet. As we have in the guide,
Instances upgraded from an earlier version keep creating v4 cleartext content until an administrator enables encrypted metadata from Administration > Resource types > Getting started with “Enable encrypted metadata and new resource types (recommended)”. Save it.
Once this is done all your new resources will be V5 and eligible for offline access for supported types.
If you want your existing legacy resources to get this option too, you can migrate metadata as explained in this guide.
Whoops, my bad. After following your directions it works like a charm.
Thank you so much.
Stefano.
