Updating Passbolt CE on Debian
I receive this error when attempting to update Passbolt CE to 5.2.0-1;
Reading package lists…
Building dependency tree…
Reading state information…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
passbolt-ce-server : Depends: php-cli (>= 2:8.2)
Depends: php-curl (>= 2:8.2)
Depends: php-mbstring (>= 2:8.2)
Depends: php-intl (>= 2:8.2)
Depends: php-mysql (>= 2:8.2) but 2:7.4+76 is to be installed
Depends: php-fpm (>= 2:8.2)
Depends: php-xml (>= 2:8.2)
Depends: php-gd (>= 2:8.2)
E: Unable to correct problems, you have held broken packages.
Machine is about 3 years old and is running only Passbolt for all of that time.
Thank you.
Hi ncastle, if your machine is only hosting passbolt you could remove the old php version its running to keep the system clean and install php 8.2 or greater - since passbolt switched to a newer version.
Would be the easiest way, you could to it by uninstalling every older php-version
#sudo apt remove php7.*
//Depends on your way of handling it
and get the 8.2 with the tweaks PB requires
sudo apt-get install php8.2 php8.2-cli php8.2-curl php8.2-mbstring php8.2-intl php8.2-mysql php8.2-fpm php8.2-xml php8.2-gd
update your php default settings (for your webservice too)
sudo update-alternatives --install /usr/bin/php php /usr/bin/php8.2 82
#sudo update-alternatives --config php
That should do the trick
Keep us updated if possible
best regards :slight_smile:
