Hello @iloh, Mutliple URIs are tied to E2EE metadata.
Can you double check that you’ve enabled it in Organisation Settings ? If it’s an old installation you might see “Get started” you will need to configure it from there. After that, when creating a new resource in Metadata you should see URIs and you will be able to add multiple URIs.
PS 2 : In the status report, i have an error [FAIL] A valid JWT key pair is missing. inspite of the fact i just recreate them. I also have at the end messages :
2025-09-30 09:48:06 error: [Cake\Routing\Exception\MissingRouteException] A route matching “/metadata/keys/settings.json” could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 248
Request URL: /metadata/keys/settings.json?api-version=v2
2025-09-30 11:48:15 error: [Cake\Http\Exception\BadRequestException] La création/modification de ressource avec des métadonnées en clair n’est pas autorisée. in /usr/share/php/passbolt/plugins/PassboltCe/Metadata/src/Utility/MetadataSettingsAwareTrait.php on line 99
