[v.2.0.0-rc2]Error after upgrade to v2 RC
I just upgrade my v1.6.9 to v2.0.0-rc2 and get stuck with an error on the front page:
“Could not verify server key. Server code: That version of GPGAuth is not supported. (undefined)”
I looked at issue about this message but it’s doesn’t help.
I found 2 majors problems.
1- on cake log:
2018-03-09 16:18:34 Error: [PDOException] SQLSTATE[HY000]: General error: 1267 Illegal mix of collations (utf8mb4_unicode_ci,IMPLICIT) and (utf8mb4_general_ci,IMPLICIT) for operation ‘=’
Request URL: /auth/verify.json?api-version=v1
I check the schema and field and table have utf8mb4_unicode_ci as collation, bu utf8mb4_general_ci is the default collation of mariadb server. So I changed the default collation of the server but it doesn’t solve this error. Is it possible to set the collation when PDO connect to mysql?
2- Healtcheck cli show me errors:
[FAIL] The public key file is not defined in config/passbolt.php or not readable.
[HELP] Ensure the public key file is defined by the variable passbolt.gpg.serverKey.public in config/passbolt.php.
[HELP] Ensure the public key defined in config/passbolt.php exists and is accessible by the webserver user.
[HELP] See. ------
[HELP] Ensure the private key file is defined by the variable passbolt.gpg.serverKey.private in config/passbolt.php.
[HELP] Ensure the private key defined in config/passbolt.php exists and is accessible by the webserver user.
[HELP] See. -----
[FAIL] The server key fingerprint doesn’t match the one defined in config/passbolt.php.
[HELP] sudo su -s /bin/bash -c “gpg --list-keys --fingerprint --home /home/www-data/.gnupg” www-data | grep -i -B 2 ‘SERVER_KEY_EMAIL’
[HELP] See. ----
I don’t understand it’s the same value than passbolt v1 setup and I cp the key with the same user/right.
I’m running passbolt on debian 9.3, php7.1, mariadb 10.1.
Can you execute the query mentioned by @kevin here:
The configuration naming conventions have changed from v1 to v2. Make sure you start a new configuration using the v2 template.
The query listed some fields in file_storage. I altered the schema to force collation and now everything is working: website, api.
But the healtchek command still failed (strange).
Thank you for your help.
