“We need to generate a lot of random bytes. It is a good idea to perform
some other action (type on the keyboard, move the mouse, utilize the
disks) during the prime generation; this gives the random number
generator a better chance to gain enough entropy.”
A workaround for your issue would be to install on your system rng-tools or haveged to increase entropy. Just take a minute and read and understand the security implications of using this tools
Hi again @nandagopal.thekkedat glad to see entropy is not a problem anymore. If you don’t mind please open a different thread detailing your problem with the emails so users with your same problem will have easier access to the solution.
