I upgraded my server to Passbolt 2.0.0-rc2 today and was able to get most of the way there, except the error below.
In the CakePHP logs (log/error.log
2018-03-19 01:36:43 Error: [Cake\Network\Exception\InternalErrorException] The GPG Server key defined in the config is not found in the gpg keyring
Request URL: /auth/verify.json?api-version=v1
And on the /auth/login
route, “Could not verify server key. Server code: That version of GPGAuth is not supported. (undefined)” is displayed in a red box.
I ran the health check and it didn’t return any errors. The health check verifies that the keys are properly setup, so I don’t see why this error is being thrown.
# su -c "/var/www/passbolt/bin/cake passbolt healthcheck" -s /bin/bash nginx
[PASS] PHP version 7.1.15.
[PASS] Full base url is set to https://[redacted]
[PASS] 19 tables found
[PASS] Using latest passbolt version (2.0.0-rc2).
Below are the details of my setup:
OS: RHEL 7.4
Server: nginx/1.12.2
PHP: 7.1.15 (fpm-fcgi)
DB: mysql 15.1 Distrib 5.5.56-MariaDB
Just to double check, I listed the secret keys in the nginx user’s ring and the server secret key was listed. The fingerprint also matches the one that is in the conf/passbolt.conf
file.
# su -c "gpg --list-secret-keys" -s /bin/bash nginx
/var/lib/nginx/.gnupg/secring.gpg
sec 2048R/C44D9582 2018-03-01 [expires: 2020-02-29]
uid [redacted]
ssb 2048R/D9633E38 2018-03-01
If there is anything else information-wise that could be helpful, please let me know.
