404 Error - User Does Not Exist After Migrating from MariaDB to PostgreSQL
I followed the official tutorial to migrate my database from MariaDB to PostgreSQL. After completing the migration and restarting the server. The log in works perfectly but after logging in I’m redirected to the password page which is completely empty and I get this error in the chrome console (same result on another browser):
data:{code: 404, body: ''}
message:"The user does not exist."
stack:"PassboltApiFetchError: The user does not exist.
    at $e.parseResponseJson (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:41316)
    at async Ns.get (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:137080)
    at async vo.findOne (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:212403)
    at async vo.getOrFindMe (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:212193)
    at async Gp._exec (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:476079)
    at async _.<anonymous> (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:477096)"
I follow this tutorial https://www.passbolt.com/blog/how-to-configure-passbolt-with-postgresql-experimental
I use Passbolt with docker (image passbolt/passbolt:4.9.1-1-ce-non-root)
Mariadb (10.6.4)
Postgres (16.4)
passbolt datacheck --hide-success-details
Everything is PASS
passbolt migrate_postgres
using migration paths
  • /etc/passbolt/Migrations
    using seed paths
    using environment default
    using adapter pgsql
    using database passbolt-preprod
    ordering by creation time
== 20211121231300 V340MigrateASCIIFieldsEncoding: migrating
== 20211121231300 V340MigrateASCIIFieldsEncoding: migrated 2.2398s
== 20211121231301 V340MigrateASCIIFieldsEncodingPro: migrating
== 20211121231301 V340MigrateASCIIFieldsEncodingPro: migrated 0.0149s
== 20211122732400 V350ConvertIdFieldsToUuidFields: migrating
== 20211122732400 V350ConvertIdFieldsToUuidFields: migrated 0.4594s
All Done. Took 2.7250s
Passbolt can now be used with Postgres.
passbolt healthcheck
[PASS] PHP version 8.2.20.
[PASS] Full base url is set to https://
SMTP settings
[HELP] You can try:
[PASS] 51 tables found.
The result of the healthcheck is the same as before the migration.
passbolt cleanup
Cleanup shell (fix mode)
2024-11-13 10:19:27 error: [PDOException] SQLSTATE[42883]: Undefined function: 7 ERROR: operator does not exist: character = uuid
LINE 1: …" LEFT JOIN “folders” “Folders” ON “Folders”.“id” = "Permiss…
HINT: No operator matches the given name and argument types. You might need to add explicit type casts. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Statement/StatementDecorator.php on line 191
In the Passbolt logs, I see this error:
{IP} - - [13/Nov/2024:10:38:13 +0000] "GET /users/{my-user-id}.json?api-version=v2&contain%5Bprofile%5D=1&contain%5Baccount_recovery_user_setting%5D=1 HTTP/1.1" 404 367 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36"
Create a new db on postgres to see if it works with a new db → yes
Use pgloader to migrate the db from Mariadb to Postgres
Thanks for your help
