About the Installation Issues category
Do you have issues setting up passbolt? The community has your back! Please use github only to report bugs.
Important: before creating an issue please:
  1. Double check the tutorials steps and read the troubleshooting advice.
    – See. Passbolt Help | Installation
  2. Search the community forum for similar issues and try to follow the resolution steps if applicable.
    – Search results for '' - Passbolt community forum
  3. Provide your system information:
    – Server operating system name and version
    – Web server name and version
    – Database server name and version
    – Php version
    – Passbolt version
  4. Provide a copy of your healthcheck running as the web server user
    – See Step 8 here: Passbolt Help | Install passbolt API from source
  5. Describe the problem thoroughly with as much details as possible so that people can reproduce the issues.
    – What steps did you take?
    – What happened?
    – What did you expect instead?
Passbolt won't send mails but send_test_email does
New Installation - PHP not processing
Fatal Error on Instalation
CentOS 7 - Nginx Webserver not reachable
[v2.0.0-rc2] That version of GPGAuth is not supported and server key not in keyring
Ubuntu 22.04 Installation Issue
CE on Centos 7 - Installer issues
Docker install issues
[v2.0.0] That version of GPGAuth is not supported
Passbolt Minor Update unkown error
Passbolt Behind Nginx Reverse Proxy
The OpenPGP key for the user could not be imported in GnuPG
LetsEncrypt / nginx Issues
Passbolt 2.5.0 install on Centos 7 stuck on step 7
Passbolt installation issues
Issue with synchronisation with AD
Passbolt Dead after Update - Ubuntu 22.04 ERR_TOO_MANY-REDIRECTS
Reinstall passbolt stuck at server keys
Cake Exception: "Argument 1 passed to App\View\Helper\AvatarHelper::getAvatarUrl() must be an instance of App\Model\Entity\Avatar, null given..."
Enabling JWT to leverage Mobile app breaks web Auth
Traefik, cloudflared and passbolt not working together
I can not login
Docker gpg keys
MissingControllerException after installation
Migrating to Another Server "Could Not Verify Server Key"
[DEBIAN] first-time configuration fails after adding user
Emails do not enqueue
Vanilla server?
Install passbolt behind an existing Nginx Reverse Proxy
SQL Errors right after install via docker
Unable to synch Alpha and Beta database in a DR setup
Can't navigate to site once installed
Recieve Test Email, But No Others
Container restarted - unable to login
Segmentation fault (Core dumped) error
Centos7 installation / Invalid installer signature
Passbolt CE 3.7.1 keeps directing to install extension
Installation from zero stuck
Cannot login - The plugin is installed but not configured
404 error after first time install
The public key cannot be used to verify a signature after upgrade to 2.4.0
Can't login after update
Email issues when trying to recover lost or new password
Error! Something unexpected happened. The setup cannot be completed
Very slow loading
Some newbie questions and issues
SMTP Mail Account Credentials
Passbolt installation issues Centos 7
Stuck on "loading, please wait" and JS errors after upgrade to v2 from v1
Difficulties updating version (fatal: Not a git repository)
LDAP AD: can't re-add users
Docker Install and CLI
Recover account on a network without email
Problem with connection database mariadb
The installation doesn't finish
Debian 9 Installation
Hashsum Mismatch
Passbolt behind marathon-lb 400 Bad Request The plain HTTP request was sent to HTTPS port
An internal error occurred when trying to share a resource with a group
Issues to upgrade from CE to Pro (v2)
Cannot login with fresh install
Problem about normal installation
Support for ECC keys (and not just RSA)
Inappropriate ioctl - Generating PGP key
Impossible to configure Passbolt [Ubuntu 18.04 / PB 2.8.3]
Scrolling not advancing or refreshing list of password entries
Passbot on CentOS fails database configuration
DirectorySync issue after upgrading from 2.8.3 to 2.9.0
Unable to deploy helm chart - error 500 and waiting for database
The passbolt page is not landing
This installation is not up to date it should be v2.8.2
Page not found via Https
Apache2 Blank page after installing from source
Unable to install manual SSL
Live migration of vm to new server now I can not access passbolt
Entropy on VMware VM
Debian package installation error
Ngnix default page
Avatars cannot be set properly
[resolved]Patch issues from 2.12.0 to 2.12.2
Upgrade from 2.13.5-pro to 3.0.0-pro docker didn't show passwords (with solution)
Problem connecting to database
CentOS https is now working - local installation (private IP) and NAT over public IP
Could not verify server key
Group handling in 2.11.0 CE does not work
SMPT "Connection Refused" Debian 9
New account creation fails with "OpenPGP key cannot be used for encryption."
Issue when creating a resource using the API
How do I migrate to a new domain?
Could not verify server key. There was an error during authentication
Step 2 Configuration Loads CentOS Welcome Page
Database connection issue while installing
Unspecified error while "Generating the secret and public key" for new users
Emails will not be sent
Activation email not working
New user emails stopped working
Docker Stuck Loading After Install with nginx proxy
Installation seemingly successful, but doesn't work
SMTP time out, even though details are correct
How do I find what port my database is using?
Update 2.11.0 to 2.12.0
Passbolt stops working after PHP upgrade
Internal error occur on passbolt page
Troubles implementing Passbolt CE on Openshift 4.10
Internal error has occurred when logging in
[SOLVED] Test email working, recover email not working, user creation email working
How to clear an installation to restart the wizard
Verification emails are never sent to SMTP server
Download and execute the installation script issue
EMAIL_TRANSPORT_DEFAULT_TLS seemingly ignored
Installation fails: usermod www-data is currently used by process 875
Unable to activate MFA
Installation wizard fails when setting up the database tables
Unable to move past database step
Issues with connecting email
Unable to Restore after updating server key expiry
Php not reading the key fingerprint appropriately in config/passbolt.php
Installation LDAP || /var/www/passbolt Directory doees not exist
The GPG keyring location is not set error
Default page-Welcome to nginx!
Docker not sending emails
"There was an error updating the data" on App (Android) and Passbolt-CE
SMTP Timeout on port 465
Passbolt not send mail and I can't login
Web interface problem
Issue with login
Unable to receive email, for account recovery
No mails sent from passbolt
Docker container tcp redirection
Install problem - ERROR
Is there a way to activate users without access to emails?
Passbolt emails are created in DB but not sent [incorrect server time]
Passbolt web Interface is broken
Can't find test email script
How to auto renew Let's Encrypt? [port 80 was not open]
Passbolt installation showing is a demo
Healthcheck: App.fullBaseUrl is not set to HTTPS
Migration V2.13.5 to V3.0.1 issue
Nginx welcome page after migrating to Ubuntu package (20.04.2)
Problem after restoring Passbolt Server on a different machine [unable to reproduce]
Fresh install, can't set Server Keys
Issue with recovery email is not being send/received
Installing Passbolt with Docker on Plesk
Login failed: Gnupg confirmation not available or incomplete
Can't import/create gpg key
Cant remove passwords after upgrade to 3.1.0
As an admin I should be able to force MFA setup and MFA at every login for my users
SMTP through port 25 without TLS or SSL encryption
Bug: Folder inheritance doesn't work like expected
The authentication failed. in /usr/share/php/passbolt/src/Controller/Auth/AuthLoginController.php on line 103
502 Bad Gateway Docker ipv4
404 not found error with apache fresh install
After Ubuntu 18.04 ec2 restart the public Ip changed and throws internal server error
Cannot send email to Gmail SMTP-Relay
Can't go pass the database connection page
Emails not being sent automatically (cronjob)
There was a problem connecting to the database
Firefox/Chrome Plugin v3.0.0 problems with users
1st time docker installation
Gnupg extension is causing issues
Intermittent issue - Could not verify the server key. The authentication failed
Notification mails not send but Testmail working
Pasbolt Docker main page
Change hostname instruction
Debug logs Mobile Phone Onboarding
Debian packet not working after upgrade PHP and PB 4.0
Issues upgrading to V3 in docker
Changing fullBaseUrl
Problems with SSL certificate (newbie question?)
Authentication error on all accounts after update
Issue “Not found error"
Passbolt Kubernetes: Experiencing "You need an account to login" during fresh installation
Multiple Domains for one pb-instance
Can't get installation page, but get nginx page
Sending email by CLI works just fine, but cronjob do not
Extension not detected
Empty page after login
HTTP to HTTP configuration problem
Gnupg issue following install (500 server error)
[Resolv] Can't decrypt new password after upgrade
Bugfix: Upload password from csv, Cannot upload because there are Chinese characters in the csv
GPG imported key taking revoked sub-key
Unable to modify passwords
Is there any way to skip SSL certificate verification for Passbolt’s SMTP configuration UI
Ubuntu upgrade from 20.04 to 22.04 breaks Passbolt [php version ref conflict]
Error using Android app with Passbolt Cloud
Could not import the user OpenPGP key - New users only
The private key cannot be used to decrypt and verify a message
Cannot set up Passbolt in Firefox 100
Passbolt version in docker
Commands to reconfigure SMTP
Android App Something went wrong
Fresh install on Ubuntu 20.04.3 - cannot login
After migrate server, I get "Sorry, the server key has changed"
Passbolt wont get back up after reboot
As a user I can run PostgreSQL in passbolt-ce-non-root container
Could not reach the /healthcheck/status after upgrade to 4.12.1
White screen after enabling external NGINX post install
Problem with E-Mail after Update
Connecting an Android Phone with my account
Server internal error after password reset - Ubuntu Linux
An Internal Error Has Occurred Error 500
Unable to register first user
How can I host passbolt on heroku?
Unable to login following initial install
SSL Installation issues
Memory problem with LDAP in Docker
Cloudflare Tunnelling
GPG can decrypt, cannot verify
Automatically activate LDAP Users?
Mobile app error: 403 on PUT for json
Removed Passbolt ce server, reinstalled, still getting old login page
Error encrypting message: Could not find valid self-signature in key in Docker
Upgrade vom 2.4.0-debian to 3.5.0-ce - CSP errors
I accidently removed /etc/passbolt and cannot reinstall or get the missing files
AS an admin i want to change group owner
Running passbolt on context path
High Availability Passbolt
Error: Sorry, you have not been signed in
iOS/Android App HTTP Forbidden
Can't access to inital page
Cannot connect to MySQL/MariaDB
No email being sent for account recovery
Pi-Hole and Passbolt on one machine
Passbolt - Authentication is required to continue
[SOLVED] Problem Enabling SSL via Digital Ocean Droplet
Permissions errors with docker on Synology
Debian 11 clean install v3.5.0 but stuck on new user window
Email not working even if test pass
Error during checkout of "Passbolt Cloud Business (monthly)"
Trying to recover account but stuck in download extension loop
"The OpenPGP key can not be used to encrypt." in FreeBSD [$PATH not set for www user in php-fpm]
Could not verify the server key. Server internal error
Mobile connect account
Mails are not working - DB Issue?!
Fresh docker install - The key creation date must not be in the future
Passbolt Initial Setup Plugin not detected FF, Chrome, Edge
Passbolt settings for postfix SMTP (send-only)
Passbolt timing out (Oracle cloud, iptables)
SMTP not working after upgrade to 3.8.1 from 3.7
Remembering me until logout doesn't work
Update is showing php deprecated (Composer upgrade to v2 needed)
Could not enroll user on Android app
Administration page with few settings
Healthcheck URL has big symbol over the whole page
Issue with data
Restoring after fresh dnf install
Passbolt CE keeps failing on installation - Ubuntu
Connection to Mysql not possible
Js libraries not loading with Apache
GPG key problems
Issue in setup passbolt on mobile, getting gopenpgp decryption error
Can I install Passbolt with http and not https?
First mail configuration
Why can't I update passbolt from 3.8.1 to 3.8.2
Facing "The OpenPGP key can not be used to encrypt." while installation is from source code
Healthcheck errors/update
Docker Deployment suggestion - more info needed re: intermediate SSL Certificates
Blank page after config
Administration Missing Options
Passbolt CE server upgrade to 5.13.0
Duo error on setup attempt [fixed with 3.11.1]
Unable to create adminstrator account "authentification failed" [SELINUX]
Can not send test email, create any user, or get authentication email back from passbolt at login [mail host blocking From: address]
Issue with new account creation - Oracle Linux 8.5 - v3.11 - OpenPGP key can not be used to encrypt [SELINUX]
Using Android mobile app with SSL client certificate
[ERROR] [MY-011906] [InnoDB] Database page corruption on disk or a failed file read of page
Passbolt/passbolt docker container is crashing immediately with Synology Docker
[DELETE] Creating item hangs
Docker install in subdirectory
Repository issues - Checksum - Oracle Linux 8.5
Emails (using SMTP) not working, issue with wildcard certificate and server key error - Oracle Linux 8.5 - New install v3.9.0
Black screen after login
SSO Administration page is blank using Firefox (Pro 3.9.0-1-pro Docker)
Emails using SMTP not working in a new installation-CentOS 7 -version 3.9 [incorrect user in cron]
Error: The sender name should not be empty - when accessing email server settings
SMTP & SSL Errors in Email Queue
Setting up first admin user with docker says email cannot open because there's no such file
Passbolt docker installation issue with prod and dr setup
False successfully installed
Problems during CE setup via helm chart
Can't install Passbolt PRO : remi-modular : repomd.xml GPG signature verification error: Bad GPG signature
Problem with MFA and connection from a new browser [htaccess Set-Cookie header]
After Login with page
Passbolt with traefik & Let's Encrypt on docker - cannot register with the link [Cloudflare tunnel]
Problem finishing install on Ubuntu 22.04.2 LTS
Autofill and Autosave
Passbolt.php changes not taking effect
I keep getting a 404 page not found On unbuntu "Docker"
iOS setup failed
Http redirect and network call failed for mobile app
Could not reach the /healthcheck/status with url after migration
Create First Admin User
Privacy error "Your connection is not private" (internal network access is being misrouted)
CSRF token from either the request body or request headers did not match or is missing. after new install
Blank page , cannot load passwords
Passbolt pro docker not accessible after few hours
SMTP settings endpoints disabled error message after update
How to enable MFA on OnPremise Passbolt
Unable to access my passbolt server from new machine
Self registration does not work
Installation issues regarding SMTP, Postfix, Docker and Proton Mail Bridge
AWS AMI - Instance running, but now what?
Could not verify server key after initial install
SMTP server error after rotating server key
Linking Android Phone App With Account
GPG key & CentOS7
Duo MFA not working RockyLinux 9.1 [egress setsebool]
Persistent GPG Initialization Failure with Passbolt CE Docker on Ubuntu 24.04 / Kernel 6.8
Sign in emails are not sent
Synology NAS Docker - Installation OK but doesn't work
After Upgrade on new Server Private Key not valid
Docker install. Test email is OK, notification emails are sent but never received
Errors installing on Debian/Apache2
Deep trouble credentials lost
Install Passbolt without SSL enabled with helm
Nginx virtual hosts
SMTP not working Rocky Linux
Kubernetes HELM JWT Authentication plugin
GMail SMTP stopped working
Passbolt just loading on login page
Can't reach passbolt frow other machine other docker
INstall on Debian 11 (on google cloud) just brings up Nginx welcome page
Installation on to server using separate ports and docker | Not getting activation link
SSL Certificate - does not validade (healthcheck/status.json) [Apache NGINX port conflict]
Scan qr app android passbolt not working
OpenPgp data entrered issues
Docker not start after upgrade to V4, problem with key import
Migrate a server with Gmail Configuration before 29th april 2024
System Emails not being sent
How to test the SMTP
Not owner of shared folder can delete the entire folder for all users including owner
This installation is not up to date. Currently using 4.0.2 and it should be v4.1.0-rc.2
"Session authorization failed." - Passbolt iOS app
Updating Passbolt-Docker from 3.2.1-CE to 4.1.1-CE throws some errors (PHP and GPG)
An error occurred during data update (ANDROID PHONE)
Generate an OpenPGP key
Gmail SMTP not working
I can create an account manually, but I cant log in without e-mail. How can i setup this service so that I ONLY need a username/password and do not need the server to send an e-mail to log in [recovery used for all new browser-based devices]
Setup Yukibey by ENV_VAR has no effect
Exporting Private Key from Mobile App [Android]
Access Passbolt in Docker by IP/ Blank page
Debian with Apache2 Installation issues
Passbolt extension still in "Connecting your account"
While installing on CentOS7, auto ssl fails
Unable to use SMTP
Test email exception
Unable to login to passbolt
Helm installation issue
Passbolt behind NginX Proxy Manager
Permission Problems with persistent Docker Volumes stored at ./
After upgrade from 4.0.2 -> 4.1.0 upgrade default content is missing
Default passbolt authentication page
Issue with Passbolt in Rancher
I can't reach initial page but apache appears instead
A connection could not be established with the credentials
Refuse to load script
Normal login without recovery
Installation error on Ubuntu (unable to locate package)
Android: QR Code - Error During Transport Update
Docker standard image vs. Docker rootless images?
Cannot import key from old server after migration
Newest Traefik version broke PassBolt
Issues with setting up SMTP
Migrating to new passbolt on Redhat 8, cannot import old 2048 keys
Passbolt Version?
SMTP error - stream_socket_client()
Passbolt inaccessible after upgrade to 4.1.2
La validacion de la solicitud de red ha fallado
Bad checksum Aborting - Rocky Linux Installation
Bad Checksum issues
Passbolt is not accessible after update to 4.1.2-1
After upgrade passbolt to 4.1.2-1, it show me the white page after login
How can I force resend emails?
Loop in otp key on broken phone
Docker compose official image + docker nginx reverse proxy : blank page
Stuck on an error message I don't understand
Problem with reverse proxy (Migrating PRO from source to Docker PRO rootless)
Docker migration from 3.5.0 to 4.1.0-1 cause gpg error
Error "This OTP is not valid." when setting up YubiKey
Password does not work
Page Not Found - Debian 12
Non root image example for kubernetes/helm
Authentication_tokens table growing indefinitely causing slow logins
Amazon SES setup error - test mail verification authenticates, but can't send
It seems my passbolt Fingerprint doesn't match my actual fingerprint
Extract Passwords From Database Folder
So much trouble with the fingerprint check
Using certificates from remote reverse proxy (traefik)?
Can't install PassBolt ce with docker when volumes are mount to local or nfs
Firefox Browser Extension 4.3.0 (or 4.3.1) not available in store
Certbot upgrade from Python 3.6 to Python 3.9 on AlmaLinux
Problem install
After install I can´t connect to Install Page
Error Durning Install on Debian
Inital install on Rancher Kubernetes
"There was an error updating the data" with Android Mobile App and Passbolt-CE
Mobile app not allowing login
Can't install PassBolt CE on Ubuntu 22.04.3 LTS
Android App Mobile Setup - Barcode
Issue with Sending Invitation Emails for Account Creation
Cronjob for non-root docker images
Invalid generation of pgp
Need to change email address for notification
Sorry, the server key has changed. [Not New Install]
Unable to create a HA infrastructure for Passbolt
Keycloak "Not Found" error
SHA512 Checksum Bad During Install
Cloudflare configuration issue causing Chrome extension errors
Mail server with 365
Setup passbolt on another computer
Issue during Passbolt kubernetes deployment
Passbolt stopped working while away
Could not verify the server key. The authentication failed. [fingerprint problem?]
I tried to restore the Passbolt server to the Ubuntu server and get error in smtp
Gnupg extension error after PHP upgrade
Installation non compatible Galaxy s8
Cant setup Email Communication with Exchange on premise
Using HTTPS my instance on docker is not reachable
Failing restore procedure
Passbolt firefox extension issues
Docker connection to mariadb could not established
Change passbolt default install path
Can't register users "Something went wrong"
How to secure Passbolt install screen
No user creation during install
Self-Host Installation Error (Docker/Firefox Container)
Firefox extension inexplicably unable to connect. JWT authentication error
Error scanning QR code
Apache/httpd reverse proxy?
Backup old Virtual Appliance before migration
Passoblt installation setup : emit($server->run());
Passbolt SSL error
Fresh Docker Install Can't Connect to DB
OpenPGP Key Not Writable
Parse error in Helm chart deployment.yaml
Healthcheck and liveness probe 500 error
Mobile Setup: Server and client time out of sync
Error while trying to configure Passbolt email setting with OVH smt settings
I have updates from 5.4 to 5.11 in docker I can't save SMTP changes
Remove passbolt completely is there a script?
Stuck in NS_ERROR_REDIRECT_LOOP after activating Traefik
Export passwords after free tier expiration
Cant register new user account
Share with group with web UI
Error upgrading from v4.0 to v4.7 on kubernetes
Passbolt - Google Chrome slow
Key Ssl too low
GPG problem after upgrading from 3.9.0 (Docker version)
Ansible Passbolt Plugin does not handle TOTP
Webinterface error: Could not verify the server key. You are already logged in
Database: A connection could not be established with the credentials provided
MYSQL Systemctl Process fails when adding user to group
Web Proxy settings disfunction after upgrade to 4.9.0 (docker passbolt:latest)
Dynamic SSL configuration and nginx broken in latest debian ce package
Passbolt SSL alert number 42 Helm Kubernetes K3s
Login emails not sending
Auto SSL Let's Encrypt
Problem with passbolt, show "could not verify server key"
Error 401 in /auth/is-authenticated.json endpoint
Problem accessing database
Cannot login after upgrade from 4.1.2 to 4.8.0
Healthcheck fails Could not reach the /healthcheck/status with the url specified in App.fullBaseUrl
Error installing Passbolt CE on Debian 12
Administrator missing shared metadata key
SQL syntax error on Percona MySQL 8.0.36-28
White screen when attempting to access off site
Beginner Needing Help with Passbolt Setup on Debian 12
Upgrading from 2.10 to 4.8 / 502 nginx error
Docker installation - unable to create first user
Passbolt not recognized web extenssion after migration
Android app not loading anything
Cannot login to admin portal SMTP settings not configured
Help finding docs
Config file for SMTP settings?
After passbolt migration, desktop plugin works, but mobile app does not
Docker and passbolt SMTP
Backing up a docker instance using the bash script
Passbolt does not work correctly with CAPTCHA enabled in Cloudflare
Oracle Cloud and Docker Installation not accessible remotely via domain
Errors in passbolt docker environment
Docker installation (CE) and the Passbolt API status
Getting a Blank Page: TrueNAS Scale APP + Nginx Proxy Manager
Empty page randomly
"Something Went Wrong" on android phone
RHEL install errors, seems like DB issue
Administration link blank site
Application error 504
Can't use fingerprint on Android app
Android app cold-start sync takes 15–25s despite idle server — likely same root cause as the "extremely slow performance on Android" thread
Decrypt passwords manually without passbolt
Errors registering first user "Table 'passbolt.users' doesn't exist"
How to change the path to SSL certificates in .env file?
Problem with Edge extension on Terminal Server (Citrix)
Logs showing internal IP instead of X-Forwarded-For IP
Error when trying script passbolt_maintenance.sh
Cannot delete a user after metadata encryption enabled
I want to implement a master-slave switchover
Email cron not working on Passbolt docker
Trying to update our Community edition in Ubuntu
Not all logs are being removed by action_logs_purge
Error upgrading Passbolt-CE and PostgreSQL together
Android apps not working over VPN
CSRF verification fails behind Apache2 proxy
Supported PostgreSQL versions (Helm Chart installation)
Unable to connect Passbolt
Unique Problem! Packaging trouble for NixOS
Users page not accessible
Struggling setup
Passbolt Migration Database Backup does not contain latest passwords
Passbolt Windows App Black Screen on 1st install
Enrollment lost after server migration
After upgrade to Passbolt-CE-5.12 new PIN Code resource type is not visible
Does ce passbolt 4.9.1 have Groups and tags?
Blank page after installation on Debian 12
Debian 11: Unable to locate package passbolt-ce-server
Recovery -email Wrong URL
Installation assistance
[solved] [API] Cannot update since version 4.9.1
Helm installation issue. Table 'passbolt.email_queue' doesn't exist
Email not arrived for users
404 Error - User Does Not Exist After Migrating from MariaDB to PostgreSQL
Ubuntu 24.10 Installation Error
Huge SQL Backup file
Cannot read properties of undefined (reading 'armoredKey')
Can't see the configuration page, blank page
Help to activate SSL working on port 8080
2026-04-21 08:22:40 debug: The OpenPGP key can not be used to encrypt.
Regression/Logic Flaw Chrome Extension v5.14.2: "Sharing transparency" dialog allows users with "Update" rights to edit permissions and break folder inheritance
I have received error i DB after update from 5.4 to 5.12
Not loading the group items
Passbolt CE (v5.0.0.0) Error 500 on docker
La clave privada no corresponde con la clave pública restaurada
Self-registration not working
Auto renew manual SSL cert
Passbolt CE Migration database import issue
Email settings appear empty after upgrade to 5.14 CE from 5.13.4 CE
Workaround for using Passbolt CE for users on Terminal Servers
The server metadata private key is not valid. Unable to validate metadata private key (id: <UUID>) cleartext data
Passbolt Healthcheck Fails: Missing or Lost Server Key, JWT Token, and Metadata Private Key Decryption Errors After Upgrade or Instance Migration
Unable to Create first admin user
Passbolt CE Docker rootless :: Invitation emails are not received
Metadata key cannot be generated
Docker compose yaml not downloading, getting html page instead
Passbolt very slow - docker 5.6.0-1-ce
Passbolt.php is not created
Unable to Log in as an Existing User
MFA Blocks user to log-in/recover
APP_FULL_BASE_URL set but auth redirects ignore it
Import passwords in Passbolt 5.6 the description field is being stored in the notes field
Mobile app crash after two request (password and 2FA)
Queued emails not sent (invites/recovery) while test email in UI works – Kubernetes + Google Workspace relay
Passbolt-CE Docker in subfolder: Links incorrect
Critical bug: user not recognized despite valid local storage (Passbolt 5.10.x)
Unable to scan QR code on Android
Login occasionally impossible until server reboot
Issue on first boot: "Access denied for user 'passbolt'@"
SLES 15 SP6: ERROR: unable to bind listening socket for address '/run/php-fpm/www.sock': Permission denied (13)
Create user o password too long
Ugrading Debian broke Passbolt
Android - Mobile Transfer Issues - HTTP 403
HTTPS - SSL cert
HELP! Need to disable SSL temporarily
502 error after upgrade to v3.3.0
Metadata encryption fails with 400 isPublicKeyValidStrict on fresh 5.10.0-2-ce-non-root and 5.9.0-1-ce-non-root Kubernetes installation
DB-Backup Issue during Migration - Please ensure on MySQL that the user has Process priviliges
Passbolt lookup failed: Failed to fetch resource '.....'. HTTP 403. Passbolt lookup failed: Failed to fetch resource '....'. HTTP 403"
Invitation needed to access Passbolt
InitKeyring failed to load
Passbolt CE 5.17.0 upgrade blocked by SELinux dependency on openSUSE Leap 15.6
Styles broken after moving to HTTPS on DigitalOcean
RedHat supported or CentOS script modifiable...?
Troubleshooting cert error after server reboot
Redirect Loop htaccess on MacOS Server
CSRF Token mismatch
Update from CE 3.83 to higher Version not possible
Cant run Passbolt
GPG verify fails (Other actions)
PDODriverTrait.php not found
FreeBSD/Apache Tips
Uncaught CacheException: Cache engine "_cake_core_" is not properly configured
New install - HTTP ERROR 500
Passbolt in docker behind reverse proxy
Healthcheck error for clean v2.0.0-rc2 install
Passbolt v2.0.0-rc hangs at "decrypting..."
Unknown column 'EmailQueue.to' in 'field list'
Long password not entirely visible in the "Edit" window, after you click the "eye" icon
As a user I should be able to use passbolt API in a subdirectory
Error after upgrade from 1.6.10 to 2.0.7
Problem caused by centos with plesk
How to upgrade instance to pro?
DigitalOcean installer - MySQL issue
Passbolt is not sending email
An Internal error has occured
Email not sending after upgrading to v2
Migration error on upgrade from 1.6.10 to 2.0.7
Version Mismatch on Debian
The private key cannot be used to do anything here
Some tables are already present in the database,
Could not verify server key. Unable to encrypt the verify token. Error encrypting message: Could not find valid key packet for encryption in key ...222f
Healthcheck: No marker found in /var/.../gpg.php, line 166
Kubernetes Deployment unable to connect to MySQL server
