Hi everyone, and thank you for your great app.
I use Passbolt CE, which is deployed in Docker.
- Passbolt CE non-root 4.9.1
- Google Chrome Extension 4.9.3
Access is allowed only from certain IP addresses. That is, I use a VPN, and only after it is enabled do I have access to the password manager. This option is not always convenient, so I decided to allow Passbolt access from all IPs, securing it with Cloudflare WAF. One of the rules on the firewall was to enable CAPTHA, which would be triggered if I logged in from an IP address that was not specified in the rule.
After enabling this rule, Passbolt works, the login page loads, but an error occurs: Could not verify the server key. Server internal error. Check with your administrator.
Without a CAPTHA check, everything works correctly. Could you please tell me if there is any way to solve this problem or is it impossible?
Thanks in advance for your assistance!
