[√ ] I have read intro post: About the Installation Issues category
[ √] I have read the tutorials, help and searched for similar issues
[ √] I provide relevant information about my server (component names and versions, etc.)
[ √] I provide a copy of my logs and healthcheck
[ √] I describe the steps I have taken to trouble shoot the problem
[ √] I describe the steps on how to reproduce the issue
Using Passbolt Docker CE latest-non-root tag (3.5.0) + Maria DB 10.3
JWT creates successfully and all health checks passing (bar the following 3) - which I believe is expected when using Docker from my research?
- [FAIL] Could not reach the /healthcheck/status with the url specified in App.fullBaseUrl
- [FAIL] SSL peer certificate does not validate
- [FAIL] Hostname does not match when validating certificates.
[PASS] PHP version 7.4.25.
[PASS] Full base url is set to https://passbolt.<our_domain>.com
[HELP] fopen(https://passbolt.<our_domain>.com/healthcheck/status.json): failed to open stream: Connection refused
[PASS] 26 tables found
[PASS] Using latest passbolt version (3.5.0).
[WARN] The JWT Authentication plugin is disabled
[HELP] Set the environment variable PASSBOLT_PLUGINS_JWT_AUTHENTICATION_ENABLED to true
Question/Request for assistance:
Is it expected that enabling JWT via environment variables (set to true) so that we are able to make use of the mobile app functionality on the community edition, that this would then ‘break’ the web authentication functionality in that attempting to authenticate via the web produces the message:
‘The route /auth/login is not permitted with JWT authentication.’
Apologies if this is well-known or obvious, but I have referenced a few set-up guides for JWT and Mobile feature and nothing I’ve found so far explicitly states this is the case if that is correct. There are no errors in my Docker logs, so I have to assume that this is intentional to a degree.
I suspect my confusion here is a misunderstanding of the intent for the mobile app, I believed so far that it was a form of MFA, but having just now read on the forums I see that MFA may be restricted to a pro plan, is that correct?
If my assumption above is correct and JWT/Mobile access cannot work in tandem with web authentication, can someone please explain (or point me to an article I may have missed) as to how users are intended to scan their QR code from within the web UI without being able to access the /auth/login route?
Likewise, if I’m incorrect, I’d greatly appreciate a point in the correct direction as to how to get this set up. There are no obvious server-side logs stating what the issue is here outside of the friendly message being displayed when I attempt to authenticate via the web UI. My hope was that we could have both the Web auth and Mobile auth/app working together for our users that work predominantly on their mobile devices.
Any advice and assistance appreciated
