– Server operating system name and version: Ubuntu 20.04.4 LTS
– Web server name and version: nginx 1.18.0
– Database server name and version: MariaDB v15.1 Distrib 10.3.34
– Php version: 7.4.3
– Passbolt version: 3.5.0
Provide a copy of your healthcheck running as the web server user
[PASS] PHP version 7.4.3.
[PASS] Full base url is set to http://pw.sspl.org
[PASS] 26 tables found
[PASS] Using latest passbolt version (3.5.0).
I had to enable allow_url_fopen in the php.ini for the web-version of the healthcheck to not throw errors, though :///healthcheck/status reports a 404.
The Digital Ocean setup steps are fairly straightforward, but the SSL skips a bit in clarity. I had installed the Digital Ocean Passbolt Droplet from the Marketplace, but before accessing the web interface installer/configuration page, I created a DNS entry for a subdomain A record, waited for DNS to propogate where I could ping the subdomain, and then SSH’d into my instance in order to run the dpkg-reconfigure passbolt-ce-server command. Unfortunately at the end of the command, the certificates existed, but the dreaded message appeared (“Unable to install the certificate”):
IMPORTANT NOTES:
- Unable to install the certificate
- Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/pw.sspl.org/fullchain.pem
Your key file has been saved at:
/etc/letsencrypt/live/pw.sspl.org/privkey.pem
Your cert will expire on 2022-06-19. To obtain a new or tweaked
version of this certificate in the future, simply run certbot again
with the "certonly" option. To non-interactively renew *all* of
your certificates, run "certbot renew"
root@1gb-nyc1-01:/etc/php/7.4/cli# cd /usr/share/php/passbolt/root@1gb-nyc1-01:/usr/share/php/passbolt# sudo su -s /bin/bash -c "./bin/cake passbolt healthcheck" www-data
Although I looked at the nginx conf files, they’re commented that Passbolt manages them, so I wasn’t sure if I am even supposed to edit them. The only one(s) created are passbolt specific, even though I did provide my domain (pw.sspl.org) in the dpkg-reconfigure setup. Since the conf files said it was configured by Passbolt and I hadn’t yet run the Passbolt web configuration, I figured I’d go ahead and do that, and then backtrack even though the installation steps said to get SSL working first.
After configuring it and creating the first user (and getting SMTP to work), I could not get SSL to work. I tried editing the /etc/nginx/sites-available/nginx-passbolt.conf file to at least change the listen directive to 443 from the default of 80. I restarted nginx with no luck, then rebooted the droplet, also with no luck. I set the listen directive back to 80 just in case Passbolt is supposed to manage/change that on its own, and came here with some hope for guidance.
