Hi Everyone,
I’m installing passbolt on a VM using the docker installation steps.
Primary Issue
I’m running into an issue where I add my first admin and I don’t get a URL.
Health Check
From my health check this is what I see.
[PASS] PHP version 7.4.33.
[PASS] Full base url is set to https://bolt.domain.com
[FAIL] The application is not able to connect to the database.
[HELP] Double check the host, database name, username and password in /etc/passbolt/passbolt.php.
[HELP] Make sure the database exists and is accessible for the given database user.
[FAIL] No table found
[HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt install" www-data
[HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake migrations migrate --no-lock" www-data
[HELP] you can try:
[PASS] Using latest passbolt version (3.12.2).
SMTP Settings
[FAIL] 9 error(s) found. Hang in there!
SQL Connection Issues - Derived from Health check
For the unable to connect to the database from the troubleshooting steps
I’m able to connect to the DB Container, Using regular SQL commands, the database has not generated any tables, but I am able to connect to the container using those credentials.
The reason I bring up the MariaDB Connection is because my docker logs are flooded with:
Exception: Connection to Mysql could not be established: SQLSTATE[HY000] [1045] Access denied for user 'passbolt'@'172.22.0.3' (using password: YES)
In [/usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php, line 133]
I was poking around the files inside the container and I don’t have the file /etc/passbolt/passbolt.php. listed in that directory. I have a passbolt.defaults.php, I’m wondering if the required items have not generated correctly.
Current Docker Compose Config
version: '3.9'
db:
image: mariadb:10.10
restart: unless-stopped
MYSQL_DATABASE: "passbolt"
MYSQL_USER: "passbolt"
MYSQL_PASSWORD: ""
depends_on:
- db
APP_FULL_BASE_URL: https://bolt.orbitalhosting.io
DATASOURCES_DEFAULT_PASSWORD: ""
EMAIL_DEFAULT_FROM_NAME: "sample"
EMAIL_DEFAULT_FROM: "sample@domain.com"
EMAIL_TRANSPORT_DEFAULT_HOST: ""
EMAIL_TRANSPORT_DEFAULT_PORT: "465"
EMAIL_TRANSPORT_DEFAULT_USERNAME: ""
MAIL_TRANSPORT_DEFAULT_PASSWORD: ""
- ./ssl/fullchain.pem:/etc/letsencrypt/live/bolt.domain.com/fullchain.pem ssl/
- ./ssl/privkey.pem:/etc/letsencrypt/live/bolt.domain.com/privkey.pem ssl/
#- 80:80
#- 443:443
- 8081:8081
- 4433:4433
database_volume:
gpg_volume:
jwt_volume:
Troubleshooting Steps
To address the URL issues, I’ve found post on the forums where removing the docker volumes and starting again resolved the issue but that has not worked for me.
Force recreate when bringing up docker-compose
Run Health Check
Tested SQL Credentials by exec into the DB container
Any additional steps and suggestions would be awesome.
Thanks in advance.
