Testing of Mobile application registration on docker integration
- Docker server is ubuntu
- Mobile app is iOS version
Behavior observed:
When trying to input the credential on my smartphone after having valided the pairing JWT the mobile app sign in is failing.
When checking unhidden the credential in the field, the credential seems correct.
And no error is displayed in the logs
Reproducing behavior:
1- Enabling JWT for Mobile tokens creation in docker : OK / Easy
2- Pairing user account in Passbolt:
- Opening Mobile section requested to input credentials
- Validated credentials
- Clicked on Start pairing displayed the 1st QR code generated
- Opened mobile app and clicked on Scan QR code started to scan each QR code generated with datas transfered to mobile
- Finished correctly to scan QR codes displayed the login screen in mobile app
- Tried to input credentials but is answering “Sign in failed”
Healthcheck:
// _,///./_//__/
A JWT key pair was successfully created.
Public key path: /etc/passbolt/jwt/jwt.pem
Secret key path: /etc/passbolt/jwt/jwt.key
// _,///./_//__/
[PASS] PHP version 7.4.25.
[PASS] Full base url is set to https://passbolt.xxxxx.fr:4443
[PASS] 26 tables found
[PASS] Using latest passbolt version (3.3.0).
Logs:
10.0.0.27 - - [21/Nov/2021:18:57:08 +0000] “POST /auth/login.json?api-version=v2 HTTP/2.0” 200 4703 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
2021-11-21 18:57:08,077 INFO reaped unknown pid 392 (exit status 0)
2021-11-21 18:57:08,078 INFO reaped unknown pid 394 (exit status 0)
10.0.0.27 - - [21/Nov/2021:18:57:08 +0000] “GET /app/settings/mobile HTTP/2.0” 200 1158 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:08 +0000] “GET /auth/is-authenticated.json HTTP/2.0” 200 338 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:08 +0000] “GET /resources.json?api-version=v2 HTTP/2.0” 200 177548 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:09 +0000] “GET /auth/is-authenticated.json HTTP/2.0” 200 338 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:09 +0000] “GET /account/settings.json?api-version=v2 HTTP/2.0” 200 1104 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:09 +0000] “GET /settings.json?api-version=v2 HTTP/2.0” 200 4062 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:09 +0000] “GET /users/9242a3a2-384f-48a8-a13e-679969badf4e.json?api-version=v2&contain%5Bprofile%5D=1 HTTP/2.0” 200 4761 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:09 +0000] “GET /resource-types.json?api-version=v2 HTTP/2.0” 200 5023 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:09 +0000] “GET /roles.json?api-version=v2 HTTP/2.0” 200 1385 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:45 +0000] “POST /mobile/transfers.json?api-version=v2 HTTP/2.0” 200 1260 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:46 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 901 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:47 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 901 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:48 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 901 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:49 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 901 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:50 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 901 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:51 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 901 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:52 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 901 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:53 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 901 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:54 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 901 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:55 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 901 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:56 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 907 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
2021-11-21 18:57:56,294 INFO reaped unknown pid 397 (exit status 0)
2021-11-21 18:57:56,294 INFO reaped unknown pid 399 (exit status 0)
10.0.0.23 - - [21/Nov/2021:18:57:56 +0000] “PUT /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971/104289ba-02a2-4743-9eb4-fcb959db290f.json?contain%5Buser.profile%5D=1 HTTP/2.0” 200 1999 “-” “Passbolt/1634501321 CFNetwork/1240.0.4 Darwin/20.6.0”
10.0.0.27 - - [21/Nov/2021:18:57:57 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 907 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.23 - - [21/Nov/2021:18:57:58 +0000] “PUT /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971/104289ba-02a2-4743-9eb4-fcb959db290f.json HTTP/2.0” 200 930 “-” “Passbolt/1634501321 CFNetwork/1240.0.4 Darwin/20.6.0”
2021-11-21 18:57:58,199 INFO reaped unknown pid 402 (exit status 0)
2021-11-21 18:57:58,199 INFO reaped unknown pid 404 (exit status 0)
10.0.0.27 - - [21/Nov/2021:18:57:58 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 907 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:57:59 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 907 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.23 - - [21/Nov/2021:18:58:00 +0000] “PUT /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971/104289ba-02a2-4743-9eb4-fcb959db290f.json HTTP/2.0” 200 930 “-” “Passbolt/1634501321 CFNetwork/1240.0.4 Darwin/20.6.0”
2021-11-21 18:58:00,232 INFO reaped unknown pid 407 (exit status 0)
2021-11-21 18:58:00,232 INFO reaped unknown pid 409 (exit status 0)
10.0.0.27 - - [21/Nov/2021:18:58:00 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 907 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:58:01 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 907 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.23 - - [21/Nov/2021:18:58:02 +0000] “PUT /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971/104289ba-02a2-4743-9eb4-fcb959db290f.json HTTP/2.0” 200 927 “-” “Passbolt/1634501321 CFNetwork/1240.0.4 Darwin/20.6.0”
2021-11-21 18:58:02,082 INFO reaped unknown pid 430 (exit status 0)
2021-11-21 18:58:02,082 INFO reaped unknown pid 432 (exit status 0)
10.0.0.27 - - [21/Nov/2021:18:58:02 +0000] “GET /mobile/transfers/41cc49c6-e7cb-41b2-99e2-0a9389eda971.json?api-version=v2 HTTP/2.0” 200 904 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.27 - - [21/Nov/2021:18:58:08 +0000] “GET /auth/is-authenticated.json HTTP/2.0” 200 338 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
10.0.0.23 - - [21/Nov/2021:18:58:31 +0000] “GET /auth/jwt/rsa.json HTTP/2.0” 500 349 “-” “Passbolt/1634501321 CFNetwork/1240.0.4 Darwin/20.6.0”
2021-11-21 18:58:31,343 INFO reaped unknown pid 436 (exit status 0)
2021-11-21 18:58:31,343 INFO reaped unknown pid 437 (exit status 0)
2021-11-21 18:58:31,344 INFO reaped unknown pid 441 (exit status 0)
2021-11-21 18:58:31,344 INFO reaped unknown pid 440 (exit status 0)
10.0.0.23 - - [21/Nov/2021:18:58:31 +0000] “GET /auth/verify.json HTTP/2.0” 200 2229 “-” “Passbolt/1634501321 CFNetwork/1240.0.4 Darwin/20.6.0”
10.0.0.23 - - [21/Nov/2021:19:43:19 +0000] “GET /auth/jwt/rsa.json HTTP/2.0” 500 349 “-” “Passbolt/1634501321 CFNetwork/1240.0.4 Darwin/20.6.0”
