Gnupg extension error after PHP upgrade
I have followed the steps in this tutorial to upgrade PHP 7.4 to 8.3. I have upgraded the PHP as well the modules and the system is running on the browser. However, when I want to run the upgrade or healthcheck script on the command line, it shows me this error:
PHP Fatal error:  You must enable the gnupg extension to use Passbolt. in /etc/passbolt/requirements.php on line 31
I have read the forum and teste this command
php8.3 -i | grep gnupg
and this is the output
/etc/php/8.3/cli/conf.d/20-gnupg.ini,
gnupg
gnupg support => enabled
Browser Healthcheck output:
Passbolt API Status
PHP version 8.3.0.
PHP version is 8.1 or above.
PCRE compiled with unicode support.
The temporary directory and its content are writable and not executable.
The logs directory and its content are writable.
GD or Imagick extension is installed.
Intl extension is installed.
Mbstring extension is installed.
SSL access is enabled.
The application config file is present
The passbolt config file is present
Debug mode is off.
Cache is working.
Unique value set for security.salt
Full base url is set to ***
App.fullBaseUrl validation OK.
/healthcheck/status is reachable.
The application is able to connect to the database
31 tables found
Some default content is present
The database schema up to date.
PHP GPG Module is installed and loaded.
The environment variable GNUPGHOME is set to /var/lib/passbolt/.gnupg.
The directory /var/lib/passbolt/.gnupg containing the keyring is writable by the webserver user.
The server OpenPGP key is not the default one
The public key file is defined in /etc/passbolt/passbolt.php and readable.
The private key file is defined in /etc/passbolt/passbolt.php and readable.
The server key fingerprint matches the one defined in /etc/passbolt/passbolt.php.
The server public key defined in the /etc/passbolt/passbolt.php (or environment variables) is in the keyring.
There is a valid email id defined for the server key.
The public key can be used to encrypt a message.
The private key can be used to sign a message.
The public and private keys can be used to encrypt and sign a message.
The private key can be used to decrypt a message.
The private key can be used to decrypt and verify a message.
The public key can be used to verify a signature.
The server public key format is Gopengpg compatible.
The server private key format is Gopengpg compatible.
Using latest passbolt version (4.4.2).
Passbolt is configured to force SSL use.
App.fullBaseUrl is set to HTTPS.
Selenium API endpoints are disabled.
Search engine robots are told not to index content.
The deprecated self registration public setting was not found in /etc/passbolt/passbolt.php.
Host availability checking is disabled.
Serving the compiled version of the javascript app.
Some email notifications are disabled by the administrator.
This is on a Ubuntu 20.04.6 LTS + Nginx 1.18.0. The Passbolt CE has been installed through DigitlaOcean’s 1-click install package.
Please let me know your thoughts on this.
Thanks
[X ] I have read the tutorials, help and searched for similar issues
[X ] I provide relevant information about my server (component names and versions, etc.)
[X ] I provide a copy of my logs and healthcheck
[X ] I describe the steps I have taken to trouble shoot the problem
[X ] I describe the steps on how to reproduce the issue
hey @wwiit welcome to the forum!
Right now we don’t support php 8.3 as it was just released and we need some time to make sure it works.
For your particular update issue though I would recommend following one of our guides for migrating to a new server which has a a more recent version of php installed by default instead of adding a ppa and trying to update that way
Thanks @clayton .
However, the problem was not setting the default PHP version to newly installed 8.3 version. I did the sudo update-alternatives --set php /usr/bin/php8.3 and everything is working fine again.
