Users/Recover failed with internal Error
Hi all,
I’ve just finished to install the 2.0.7 passbolt version on a new server.
I restore the database from the 1.6.9 , and follow the Upgrade Tutorial.
[PASS] PHP version 7.0.27-0+deb9u1.
[PASS] Full base url is set to https://myserver.fr
[PASS] 23 tables found
[PASS] Using latest passbolt version (2.0.7).
Unfortunately, i can’t recover any account, with error message " You are not authorized to access that location , An internal error has occured" .
Can’t understand what’s happening ?
Cheers
Val
Can you check if there is more information in logs/error.log (from your passbolt directory).
Check also if the database table encoding / collation is set properly, this is a common issue with the upgrade:
Hi Remy,
Thank you for your very quick reply.
logs are speaking !
2018-05-28 14:05:40 Error: [InvalidArgumentException] Invalid header value type; must be a string or numeric; received boolean
Request URL: /healthcheck/status.json
2018-05-28 14:07:13 Error: [PDOException] SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘Gpgkeys.armored_key’ in ‘field list’
Request URL: /auth/verify.json?api-version=v1
2018-05-28 14:10:15 Error: [PDOException] SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘Gpgkeys.armored_key’ in ‘field list’
Ok , errors with the database.
As “JPMDWX”
I’ve dropped my schema and imported it again from backup. Then, I ran the migration script and now is working fine!!
Thanks a lot for all your help!!!
Best regards
