I recently restored our database from backup and whenever we land on the landing page we are presented the recovery wizard> recovery works sigh out and go to log in again have to recover again.
Hi @ganosh Welcome to the forum!
Please provide version details for OS, passbolt, browser extension, php, NGINX, and run the healthcheck if you can, thanks.
Ubuntu 20.04
Passbolt CE 3.6.0
Cakephp 4.3.7
[PASS] PHP version 7.4.3.
[PASS] Full base url is set to https://*****
[PASS] 26 tables found
[FAIL] Could not connect to passbolt repository to check versions It is not possible check if your version is up to date.
Never mind the migration portion. Fresh install on the same server I am getting the same issue, blank database new keys.
Purge passbolt-ce-server
purge nginx*
purge php*
log into mysql drop tables
purge mysql*
autoremove
is there another component or files I need to remove for this to stop?
The extension does not display the sign-in form if the url is not recognized as the one used to setup/recover an account.
Can you confirm that your /etc/passbolt/passbolt.conf doesn’t contain an App.fullBaseUrl with a trailing slash.
(Edit: /etc/passbolt/passbolt.php)
Could you provide us with the browser extension debug log:
On Chrome:
New tab > go to chrome://extensions > look for passbolt card > details > inspect views section > click index.html > unfold and copy errors under console tab
On Firefox:
New tab > go to about:debugging#/runtime/this-firefox > look for passbolt card > Click inspect > unfold and copy errors under console tab
There is no /etc/passbolt/passbolt.conf
I have passbolt.php on a hunch I added the missing trailing “/” and now it works as expected
after one last recovery in both firefox and edge was needed
I also removed the “/” and it is now working as expected.
@ganosh Good to hear! That’s correct - he meant passbolt.php.
