Authentication failed
I’ve installed passbolt on my server. But I cannot log in. I’ve got a below error in application’s log:
Error: [Cake\Http\Exception\ForbiddenException] You need to login to access this location.
(path/src/Auth/GpgAuthenticate.php:85)
But my password is correct :confused:
My healthchecker report
[PASS] PHP version 7.3.26.
[PASS] Full base url is set to https://passbolt…
[PASS] 23 tables found
[PASS] The environment variable GNUPGHOME is set to …/.gnupg.
[PASS] The directory …/.gnupg containing the keyring is writable by the webserver user.
[PASS] Using latest passbolt version (2.13.5).
PHP 7.3, centos 7, MariaDB 10.5
queue works fine
no errors in my apache logs
cookies are created correctly
Hi @marcus Welcome to the forum! And thank you for the details, this is very useful.
You are saying you cannot login - this implies you already registered your admin user? Please clarify from a user standpoint the process/stage where you are experiencing this, thanks.
HI @garrett!
Yes, I created an admin user (Organization administrator) correctly. My account is active.
I try to log in using a form
When I click “login”, a page is refreshed and the error occurs in the log.
@marcus Normally there is an error message in the login form that says the passphrase is incorrect. But to confirm, you are saying the page refreshes there is no error message. Correct?
Almost like it is logging you out right after submitting your passphrase? Maybe something like this:
@garrett
After I enter a wrong password I’ve received an error message. It means that I’ve been entering the correct password.
The case which you shared with me does not look like my issue. I’ve full access to use cookies with chrome.
@marcus
Next step could be to turn on debug in config/passbolt.php file by adding:
return [
    'debug' => 'true',
    'App' => [
Website will say “Unsafe Mode” in footer on login page if debug is successfully enabled. You can comment it out when done using.
You’ll also want to make sure there is a “debug.log” file in the logs folder, writable by webserver user (on my Centos7 install it’s nginx).
I’ve just noticed below issue in chrome extension
Access to fetch at ‘https://passbolt.greenkale.dev/auth/is-authenticated.json’ from origin ‘chrome- extension://didegimhafipceonhjepacocaffmoppf’ has been blocked by CORS policy:
Response to preflight request doesn’t pass access control check: No ‘Access-Control-Allow-Origin’ header is present on the requested resource. If an opaque response serves your needs, set the request’s mode to ‘no-cors’ to fetch the resource with CORS disabled.
Debug mode hasn’t logged any error.
@marcus I have not seen this before. Are you proxying to a backend with a different domain? You could try reinstalling the extension and recover your user.
I’ve done how you wrote and now it’s working fine :crazy_face:
Prolly it’s something with connection between chrome extension and web site :thinking:
thx for a tip :clap:
