Can't navigate to site once installed
Hi all,
This is the second time I have tried to install Passbolt and keep getting stuck at the same issue. Everything seems to be set up properly but right now I am just getting the Apache default page. I am pretty confident it has to do with my apache setup (I am fairly new to web servers) but I do already have another website up and running on my local network so I know the web server is setup at least somewhat properly. My other site running on the server is http as well. The first time I did the installation I was able to get to the plugin page by forcing my url to /index.php but have not been able to do that with this second try which gives me a “requested url not found” error. I followed the Debian 9 install guide.
I am using an Apache web server on Ubuntu 16.04. My database is setup on a separate server than the web server. I am including my health check, site-available conf file, passbolt.php file (The relevant parts at least).
Here is my health check
www-data@localhost:~/passbolt$ ./bin/cake passbolt healthcheck
 [PASS] PHP version 7.1.20-1+ubuntu16.04.1+deb.sury.org+1.
 [PASS] Full base url is set to http://passbolt.pzebra.com
 [PASS] 18 tables found
 [PASS] Using latest passbolt version (2.1.0).
 [FAIL] Passbot is not configured to force SSL use.
5 error(s) found. Hang in there!
Passbolt.php
‘App’ => [
‘fullBaseUrl’ => ‘http:// passbolt. company. com’,
    // Database configuration.
    'Datasources' => [
        'default' => [
            'host' => 'Host_IP',
            //'port' => 'non_standard_port_number',
            'username' => 'passbolt',
            'password' => 'Password',
            'database' => 'passbolt',
    // Email configuration.
    'EmailTransport' => [
        'default' => [
            'host' => 'localhost',
            'port' => 25,
            'username' => 'user',
            'password' => 'secret',
            'tls' => null,
            //'timeout' => 30,
            //'client' => null,
            //'url' => null,
    'Email' => [
        'default' => [
            'from' => ['passbolt@your_organization.com' => 'Passbolt'],
            //'charset' => 'utf-8',
            //'headerCharset' => 'utf-8',
'passbolt' => [
        // GPG Configuration.
        'ssl' => [
            'force' => false,
        'gpg' => [
            // If putenv is set to false, gnupg will use the default path ~/.gnupg.
            // For example :
            // - Apache on Centos it would be in '/usr/share/httpd/.gnupg'
            // - Apache on Debian it would be in '/var/www/.gnupg'
            // - Nginx on Centos it would be in '/var/lib/nginx/.gnupg'
            // - etc.
            //'keyring' => getenv("HOME") . DS . '.gnupg',
            //'putenv' => false,
            // Main server key.
            'serverKey' => [
                'fingerprint' => 'BFB16DDEBD66416F45F9BF5DBAFB708A7B77F58A',
                //'public' => CONFIG . 'gpg' . DS . 'serverkey.asc',
                //'private' => CONFIG . 'gpg' . DS . 'serverkey_private.asc',
sites-available/passbolt.conf
<VirtualHost *:80>
ServerName http:// passbolt. company. com
DocumentRoot /var/www/passbolt
    <Directory /var/www/passbolt>
        Options FollowSymLinks
        AllowOverride All
        Require all granted
    </Directory>
</VirtualHost>
netstat:
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      1527/mysqld
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1217/sshd
tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      1553/postgres
tcp        0    480 10.x0.x8.x1:22        10.x0.x8.x1:60437     ESTABLISHED 2104/sshd: user1
tcp6       0      0 :::80                   :::*                    LISTEN      1561/apache2
tcp6       0      0 :::22                   :::*                    LISTEN      1217/sshd
tcp6       0      0 ::1:5432                :::*                    LISTEN      1553/postgres
tcp6       0      0 :::443                  :::*                    LISTEN      1561/apache2
udp        0      0 0.0.0.0:68              0.0.0.0:*                           981/dhclient
udp6       0      0 ::1:41058               ::1:41058               ESTABLISHED 1553/postgres
Not sure where to turn to now. Let me know if any other files are need or any other information. Thanks in advance!
*Edit: I added the spaces in the url because I am a new user. The real files do not have the spaces.
Hello @jrik,
Is there also a sites-enabled/passbolt.conf?
Did you restart your apache ?
Cédric
Well this is embarrassing
 Haha thanks for the quick answer! Marking as solved.
