[ x ] I have read intro post: About the Installation Issues category
[ x ] I have read the tutorials, help and searched for similar issues
[ x ] I provide relevant information about my server (component names and versions, etc.)
Server: Ubuntu 22.04
Passbolt: 3.8.1
[ x ] I provide a copy of my logs and healthcheck
[ x ] I describe the steps I have taken to trouble shoot the problem
[ x ] I describe the steps on how to reproduce the issue
After a successful installation following the install from source (ignoring the email, and nginx steps)
User saved successfully.
To start registration follow the link provided in your mailbox or here:
https://www.passbolt.domain.com/setup/install/uuid/uuid
Passbolt installation success! Enjoy! ☮
I go to the website an it is blank. and inspecting elements there seems to be quite a few errors
Health check
[PASS] PHP version 8.1.2-1ubuntu2.8.
[PASS] Full base url is set to https://www.passbolt.domain.com
[HELP] fopen(): Unable to locate peer certificate CN
fopen(https://www.passbolt.domain.com/healthcheck/status.json): Failed to open stream: operation failed
[PASS] 26 tables found
[PASS] Using latest passbolt version (3.8.1).
[PASS] The /var/www/passbolt/config/jwt/ directory is not writable.
SMTP Settings
[WARN] The SMTP Settings source is: /var/www/passbolt/config/passbolt.php.
My Vhosts SSL
<IfModule mod_ssl.c>
<VirtualHost _default_:443>
ServerAdmin togtja@gmail.com
ServerName passbolt.domain.com
DocumentRoot /var/www/passbolt/webroot
ErrorLog ${APACHE_LOG_DIR}/passbolt_error.log
CustomLog ${APACHE_LOG_DIR}/passbolt_access.log combined
<FilesMatch "\.(php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /var/www/passbolt/webroot>
Options FollowSymLinks
AllowOverride All
Require all granted
</Directory>
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/passbolt.domain.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/passbolt.domain.com/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
</VirtualHost>
</IfModule>
