[✓] I have read intro post: About the Installation Issues category
[✓] I have read the tutorials, help and searched for similar issues
[✓] I provide relevant information about my server (component names and versions, etc.)
[✓] I provide a copy of my logs and healthcheck
[✓] I describe the steps I have taken to trouble shoot the problem
[✓] I describe the steps on how to reproduce the issue
Hi everyone,
I haven’t updated my Docker install of Passbolt in a long time (currently on tag 2.10.0-debian) and want to update to 4.8.0-1-ce.
After I have updated the docker-compose.yml and restarted the container I get an nginx error page (502). I already saw similar posts about an older version here 502 error after upgrade to v3.3.0 and here 502 Bad Gateway Docker ipv4, but the issue seems to be somewhere else, since the nginx and PHP config file were already configured correctly according to those threads. I also tried restarting the entire machine and both the SQL server container (MariaDB 10.4) and the Passbolt container.
I tried looking into the nginx logs (passbolt-error.log and passbolt-access.log), but when trying to open them with nano I get an empty file with the warning that the file cannot be opened because it is a device file.
If you need anything to help diagnose the issue let me know!
This is the healthcheck before the update:
[PASS] PHP version 7.2.18.
[PASS] Full base url is set to https://192.168.1.99
[HELP] cURL Error (60) SSL certificate problem: self signed certificate
[PASS] 26 tables found
[FAIL] This installation is not up to date. Currently using 2.10.0 and it should be v4.8.0.
[WARN] Registration is open to everyone.
[HELP] Or set passbolt.registration.public to false in config/passbolt.php.
This is the healthcheck after the update:
[PASS] PHP version 8.2.18.
SMTP settings
[HELP] You can try:
[PASS] Using latest passbolt version (4.8.0).
[PASS] 31 tables found.
