Server info:
Passbolt Version: 4.1.0.
Platform and Target:
- Operating system: Ubuntu 20.04.6 LTS
- PHP: 7.4.3
- Web server: Nginx 1.18.0
- Database server: MariaDB 10.3.38
Before upgrading from 4.0.2 to 4.1.0 the Database healthcheck was ok.
[PASS] PHP version 7.4.3-4ubuntu2.19.
[PASS] Full base url is set to https://redacted
[PASS] 30 tables found
[FAIL] This installation is not up to date. Currently using 4.0.2 and it should be v4.1.0.
[INFO] The self registration provider is: Email domain safe list.
SMTP Settings
After the upgrade to 4.1.0 this is the output:
[PASS] 32 tables found
[HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt install" www-data
[PASS] Using latest passbolt version (4.1.0).
SMTP Settings
Especially the Database section of the healthcheck concerns me:
I don’t want to use the suggested install command, since that will wipe my database.
# sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt install" www-data
Some tables are already present in the database. A new installation would override existing data.
Please use --force to proceed anyway.
So how can I fix this error without data loss?
Besides the failing healthcheck everything seems to work.
