502 error after upgrade to v3.3.0
[ *] I have read intro post: https://community.passbolt.com/t/about-the-installation-issues-category/12
[ *] I have read the tutorials, help and searched for similar issues
[ *] I provide relevant information about my server (component names and versions, etc.)
[ *] I provide a copy of my logs and healthcheck
[ *] I describe the steps I have taken to trouble shoot the problem
[ *] I describe the steps on how to reproduce the issue
I am trying to upgrade my passbolt VM to v3.3.0 from ~v2.3 and I am getting a 502 error after doing a migration.
I am running Ubuntu 20.04 with PHP 7.4 and MySQL 8 on another device on the network. I am also using an Apache server as a web proxy as I have multiple sites that are served through it.
Please let me know what logs I need to pull from my system so I can troubleshoot this.
Below is what I get when I run a healthcheck:
PASSBOLT
Healthcheck shell…Warning Error: file_get_contents(/var/www/passbolt/config/jwt/jwt.pem): failed to open stream: No such file or directory
In [/var/www/passbolt/plugins/Passbolt/JwtAuthentication/src/Service/AccessToken/JwtKeyPairService.php, line 110]
2021-10-31 22:41:59 Warning: Warning (2): file_get_contents(/var/www/passbolt/config/jwt/jwt.pem): failed to open stream: No such file or directory in [/var/www/passbolt/plugins/Passbolt/JwtAuthentication/src/Service/AccessToken/JwtKeyPairService.php, line 110]
[PASS] PHP version 7.4.3.
[PASS] Full base url is set to https://passbolt.XXXXXXX.com
[PASS] 26 tables found
[PASS] Using latest passbolt version (3.3.0).
[WARN] The JWT Authentication plugin is disabled
[HELP] Set the environment variable PASSBOLT_PLUGINS_JWT_AUTHENTICATION_ENABLED to true
The last two Nginx errors that I captured showing me trying to connect:
2021/10/31 22:48:14 [error] 3885#3885: *64 connect() failed (111: Connection refused) while connecting to upstream, client: 10.208.41.233, server: passbolt.XXXXXXX.com, request: “GET /install/system_check HTTP/1.1”, upstream: “fastcgi://127.0.0.1:9000”, host: “passbolt.XXXXXXX.com”
2021/10/31 22:53:45 [error] 3885#3885: *69 connect() failed (111: Connection refused) while connecting to upstream, client: 10.208.41.233, server: passbolt.XXXXXXX.com, request: “GET / HTTP/1.1”, upstream: “fastcgi://127.0.0.1:9000”, host: “passbolt.XXXXXXX.com”
@krosseyed your post should now be visible.
Thank you @remy for opening this back up, as I have been able to resolve my issue.
Turns out it was an Nginx error and I had followed all the steps in the following guide to resolve it:
The solution from this guide that worked for me was the following:
nano www.conf
listen = 127.0.0.1:9000
After that change, nginx started to work again. So if you are updating from 18.04 → 20.04 on ubuntu, please check that your nginx config hasn’t been modified, as it may prevent passbolt access via nginx.
Thanks for your feedback about your installation issue. I think it can help other users.
By the way, the default with Ubuntu 20.04 is now to use a socket (/run/php/php7.4-fpm.sock) instead of a TCP connection (127.0.0.1:9000).
Another solution is to edit your nginx configuration file and use this socket:
    fastcgi_pass             unix:/run/php/php7.4-fpm.sock;
Instead of the TCP connection:
    fastcgi_pass             127.0.0.1:9000;
I appreciate the followup on this. I did have to change the fastcgi_pass value to the following before it would work.
fastcgi_pass unix:php7.4-fpm.pid;
After that, we are good to go!
For anybody coming here via google - I had a 502 gateway timeout after dist-upgrade on debian 10 to debian 11 (buster to bullseye). The reason was the line
    fastcgi_pass             unix:/run/php/php7.3-fpm.sock;
in /etc/nginx/sites-enabled/nginx-passbolt.conf which had to be changed to
I got the same from Debian 11 to Debian 12, I had to update the socket path accordingly to php 8.2 version.
I got the same error after I upgraded to ubuntu 22.04
I had to change
to
fastcgi_pass unix:/run/php/php8.1-fpm.sock;
in /etc/nginx/sites-enabled/nginx-passbolt.conf to get it to work again
I found the necessary php-fpm.sock version through checking which one was listed in /run/php/
