Page not found via Https
Hi, Guys. I am having a problem with Passbolt, when I try to access via https (certificate has been properly installed), I got the answer that the page /auth/login does not exist, i need to change my baseurl (passbolt config file) to http, to be able to access again. I will try to give as much information as possible. And congratulations on the great tool.
Ubuntu Server 18.04.3 LTS
nginx version: nginx/1.14.0
mariadb Ver 15.1 Distrib 10.1.41
PHP 7.2.19-0ubuntu0.18.04.2 (cli)
Passbolt Version (2.11.0)
Health Check Log
/ _
//./_//__/
[PASS] PHP version 7.2.19-0ubuntu0.18.04.2.
[PASS] Full base url is set to http://192.168.111.128
[PASS] 26 tables found
[PASS] Using latest passbolt version (2.11.0).
[FAIL] Passbot is not configured to force SSL use.
Nginx /etc/nginx/sites-enabled/default
########## Default server configuration
server {
listen 8000 default_server;
server_name 192.168.111.128;
server {
# SSL configuration
listen 443 ssl http2 default_server;
include snippets/self-signed.conf;
include snippets/ssl-params.conf;
  root /var/www/passbolt/webroot/;
######### Add index.php to the list if you are using PHP
index index.html index.htm index.nginx-debian.html index.php;
server_name _;
location / {
# First attempt to serve request as file, then
# as directory, then fall back to displaying a 404.
try_files $uri $uri/ =404;
######### pass PHP scripts to FastCGI server
location ~ .php$ {
include snippets/fastcgi-php.conf;
fastcgi_pass 127.0.0.1:9000;
######## deny access to .htaccess files, if Apache’s document root
location ~ /.ht {
deny all;
Hi @rafaelmspc,
Thank you for reporting your issue and using Passbolt.
To help you and resolve the issue that you are having, I would like to have some more information.
  • Did you provide the https URL during or after the installation?
  • Is the healthcheck log provided was ran when Passbolt was configured with the https url?
    I am asking this question because I see in the provided Health Check Log that:
If no, can you run the command bin/cake passbolt healthcheck again when the appBaseUrl is set with https please and provide the output log?
Thanks.
Thanks for your reply.
1 - Did you provide the https URL during or after the installation?
No, i provide http.
2 - The health check posted was using as baseurl http.
Posting below the health check with the base url using https.
[PASS] Full base url is set to https://192.168.111.128
4 error(s) found. Hang in there!
Thank you.
Hi @rafaelmspc,
Can you please replace in your nginx.conf the following part:
location / {
with:
location / {
It should work like this. :slight_smile:
Please keep us updated!
It worked!
Thank you.
