Error:
Health check report:
PHP Warning: Module 'intl' already loaded in Unknown on line 0
[PASS] PHP version 7.4.3.
[PASS] Full base url is set to http://dev-passbolt.arbisoft.com
[PASS] 26 tables found
[PASS] The environment variable GNUPGHOME is set to /home/hamzapervez/.gnupg.
[PASS] The directory /home/hamzapervez/.gnupg containing the keyring is writable by the webserver user.
[PASS] Using latest passbolt version (3.8.3).
[PASS] The /home/hamzapervez/passbolt/config/jwt/ directory is not writable.
SMTP Settings
[WARN] The SMTP Settings source is: /home/hamzapervez/passbolt/config/passbolt.php.
Only one error is due to SSL and that does not seem related.
I’ve checked the NTP service and it is working fine as mentioned in this GPG-Key creation failed
All the ports are open for outbound communication.
No error in any logs. Can’t seem to figure out why is this not letting me setup a passphrase for admin user.
