debian 11
use debian package : passbolt-ce-server_3.5.0-1_all.deb (b458b3d9ca0b5edd6ec39f298d0940de [md5])
can t upload txt but it s :
cat error.log
2022-02-25 11:29:49 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/img/controls/chevron-down_blue.svg” could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Request URL: /img/controls/chevron-down_blue.svg
Client IP: 2a01:e0a:1ef:7591::9002022-02-25 11:29:53 Warning: Warning (2): file_get_contents(/etc/passbolt/gpg/serverkey.asc): failed to open stream: No such file or directory in [/usr/share/php/passbolt/src/Utility/Healthchecks/GpgHealthchecks.php, line 457]
2022-02-25 11:29:53 Warning: Warning (2): file_get_contents(/etc/passbolt/gpg/serverkey_private.asc): failed to open stream: No such file or directory in [/usr/share/php/passbolt/src/Utility/Healthchecks/GpgHealthchecks.php, line 459]
2022-02-25 11:29:53 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/img/controls/chevron-down_blue.svg” could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Client IP: 2a01:e0a:1ef:7591::9002022-02-25 11:29:55 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/img/controls/chevron-down_blue.svg” could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Client IP: 2a01:e0a:1ef:7591::9002022-02-25 11:30:47 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/img/controls/chevron-down_blue.svg” could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Client IP: 2a01:e0a:1ef:7591::9002022-02-25 11:31:39 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/img/controls/chevron-down_blue.svg” could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Client IP: 2a01:e0a:1ef:7591::9002022-02-25 11:32:26 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/img/controls/chevron-down_blue.svg” could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Client IP: 2a01:e0a:1ef:7591::9002022-02-25 11:33:40 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/img/controls/chevron-down_blue.svg” could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Client IP: 2a01:e0a:1ef:7591::9002022-02-25 11:33:53 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/img/controls/chevron-down_blue.svg” could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Client IP: 2a01:e0a:1ef:7591::9002022-02-25 11:34:12 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/img/controls/chevron-down_blue.svg” could not be found. in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Client IP: 2a01:e0a:1ef:7591::9002022-02-25 11:37:33 Warning: Warning (2): chmod(): Operation not permitted in [/usr/share/php/passbolt/plugins/Passbolt/WebInstaller/src/Utility/WebInstaller.php, line 290]
deb package installed correctly :
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii passbolt-ce-server 3.5.0-1 all Passbolt, open source password manager for teams
the web install stuck in install step as you can see the screenshot
load server at 0.00
ram free :
free -h
total used free shared buff/cache available
Mem: 1.9Gi 223Mi 543Mi 16Mi 1.2Gi 1.7Gi
stuck at step 7
thank you for your help
pra
PS : not sure the beer will be ok (ref to the phrase in the screenshot : “Brewing pale ale”)
