Notification mails not send but Testmail working
[x] I provide a copy of healthcheck
I installed the passbold (community edition) via installation script on a Ubuntu Server 18.04 (virtual machine) within a private Network (.local-Domain). With 2GB RAM
PHP is PHP 7.2.24, MariaDB Ver 15.1 Distrib 10.1.47-MariaDB, nginx/1.14.0, passbolt version 2.13.5
Check is ok:
 [PASS] PHP version 7.2.24-0ubuntu0.18.04.7.
 [PASS] Full base url is set to https://passbolt.edu-werkstatt.local
 [PASS] 23 tables found
 [PASS] Using latest passbolt version (2.13.5).
Emails send via sudo su -s /bin/bash -c "./bin/cake passbolt send_test_email is ok.
But all notification mails are not sent. Cronjob is running every minute. No errors are shown in /var/log/passbolt.log or /var/www/passbold/logs/error.log
Within the database the messages are locked (1) If I reset the locking to 0 they go into state 1 after the cron job has been running.
What ca I do about this?
Regards Matt
@matthias.graehn Hi Matt, welcome to the forum!
Since this is a fresh install can you share your SMTP setup/config? Take out enough of the sensitive data to make it appropriate to post.
Maybe also check the mysql and syslog logs to see if there is anything there.
That are the lines from config/passbold.php
// Email configuration.
'EmailTransport' => [
    'default' => [
        'host' => 'smtp.gmail.com',
        'port' => 587,
        'username' => 'support@edu-werkstatt.de',
        'password' => '*************',
        'tls' => true,
        //'timeout' => 30,
        //'client' => null,
        //'url' => null,
'Email' => [
    'default' => [
        'from' => ['support@edu-werkstatt.de' => 'EDU-Werkstatt Support'],
        'charset' => 'utf-8',
        //'headerCharset' => 'utf-8',
Within syslog theres nothing suspicious just the regular messages from the cron job
Feb  4 13:52:01 edu-ws_vm_slave_duck CRON[74391]: (www-data) CMD (/var/www/passbolt/bin/cake EmailQueue.sender >> /var/log/passbolt.log)
Feb  4 13:53:01 edu-ws_vm_slave_duck CRON[74405]: (www-data) CMD (/var/www/passbolt/bin/cake EmailQueue.sender >> /var/log/passbolt.log)
Feb  4 13:54:01 edu-ws_vm_slave_duck CRON[74426]: (www-data) CMD (/var/www/passbolt/bin/cake EmailQueue.sender >> /var/log/passbolt.log)
The logfile /var/log/passbold.log is completely empty. Permissions seem to be ok.
The logfile from maiadb shows no error for today.
@matthias.graehn Thanks, these look okay to me. Since you are running a local version, maybe you could try setting the client to a domain or ip address so Gmail has something to verify. It passes “localhost” by default and I think Gmail doesn’t like that. Another thought was about using an app password from Gmail.
thanks for taking care of this:
I have already seen this post
and changed the config to the values suggested:
    'default' => [
        'host' => 'smtp-relay.gmail.com',
        'port' => 587,
        'password' => '*********************',
        'tls' => true,
        //'timeout' => 30,
        'client' => '213.61.178.152',
        //'url' => null,
But still no luck.
What I do not understand is why is testmail working and the queue not. Is this a different process using another library or class? Or do I have to set up a MTA locally? But it should work right away, shouldn it?
Email configuration
Host: smtp-relay.gmail.com
Port: 587
Username: support@edu-werkstatt.de
Password: *********
TLS: true
Sending email from: EDU-Werkstatt Support <support@edu-werkstatt.de>
Sending email to: matthias.graehn@edu-werkstatt.de
Trace
[220] smtp-relay.gmail.com ESMTP j16sm327449wro.11 - gsmtp
> EHLO 213.61.178.152
[250] smtp-relay.gmail.com at your service, [213.61.178.154]
[250] SIZE 157286400
[250] 8BITMIME
[250] STARTTLS
[250] ENHANCEDSTATUSCODES
[250] PIPELINING
[250] CHUNKING
[250] SMTPUTF8
> STARTTLS
> EHLO 213.61.178.152
[250] 8BITMIME
[250] AUTH LOGIN PLAIN XOAUTH2 PLAIN-CLIENTTOKEN OAUTHBEARER XOAUTH
[250] PIPELINING
[250] CHUNKING
[250] SMTPUTF8
> AUTH LOGIN
[334] VXNlcm5hbWU6
[334] UGFzc3dvcmQ6
[235] 2.7.0 Accepted
> MAIL FROM:<*****>
[250] 2.1.0 OK j16sm327449wro.11 - gsmtp
> RCPT TO:<matthias.graehn@edu-werkstatt.de>
[250] 2.1.5 OK j16sm327449wro.11 - gsmtp
> DATA
[354] Go ahead j16sm327449wro.11 - gsmtp
> From: "EDU-Werkstatt Support" <*****>
To: matthias.graehn@edu-werkstatt.de
Date: Thu, 04 Feb 2021 14:27:11 +0000
Message-ID: <6a6aef38885f46beb59b72c8f140bbb4@edu-ws_vm_slave_duck>
Subject: Passbolt test email
MIME-Version: 1.0
Congratulations!
I am wondering why the /var/log/passbold.log ist still empty if something went wrong.
Any further ideas? Maybe I sould debug the cake file to see whats going on there.
Thanks and Regards
Matt
@matthias.graehn Ah, okay so you are using smtp-relay and not smtp. No local MTA should be needed.
Most of the recent discussion around smtp-relay at Gmail was in the scenario of no-auth setups which is different than your case.
Passbolt Help | Why are my emails not being sent? mentions the setttings from within the app itself - are email notifications enabled?
yes I switched from smtp.gmail.com to smtp-relay.gmail.com which does work as well for the test mail but does not make any difference for the notifications.
I also checked all the points from the Passbolt Help | Why are my emails not being sent? before I created this post.
I had the error before
Exception: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘EmailQueue.to’ in ‘field list’ ...
but was able to get rid of it through some other posts. Remove /vendor, clean cache etc.
Should I switch back to smtp.gmail.com then.
@matthias.graehn Just to confirm: you are receiving an email to your matthias.graehn@edu-werkstatt.de account after the test email command, right? If you are, the notifications from the app should deliver okay.
The part you quoted above will show even if the mail server does not deliver the message for another reason - it might accept the message, but won’t deliver it. It might get quarantined, for example.
If your domain does not require smtp-relay then I would not use it.
You can also turn on debug temporarily as shown here. Maybe that will produce something. Check your /var/www/passbolt/logs folder for a debug.log file. If it’s not there you can create and grant permission to the web server.
Try to enter in the /usr/share/php/passbolt repertories and enter the following command:
./bin/cake cache clear_all
Then, try to resend it
Hi there,
I found the problem and resolved it. For any reason the email, from_email , from_name in the table email_queue were empty. But I do not know how this happened. If I now do an action at least the email is filled within the Table. And since the values are there (in the mail) I guess they are taken from config . It is working now.
Thanks for your patience.
Regards
Matt
I have the same problem. How did you resolve it?
Thanks
Hi @Joo If you can open a new thread in the Installation section with your info that is requested in that section’s template that will be best since this one got solved. Thanks!
I’m facing the same problem, but i’m no expert in Linux, can you please advise where to change those values.
