Administration page with few settings
php 7.4.30
alma 8
installation from source code 3.7.1
/ _
//./_//__/
[PASS] PHP version 7.4.30.
[PASS] Full base url is set to XXX
[HELP] cURL Error (60) SSL certificate problem: self signed certificate
[PASS] 26 tables found
[PASS] Using latest passbolt version (3.7.1).
[PASS] The /usr/share/nginx/passbolt/config/jwt/ directory is not writable.
No error logs
My administration superuser page only shows language and email settings.
I dont know how to attach a picture here.
Are you using CE or Pro Edition?
On the CE it’s normal to have only these two admin settings.
Additional settings (account recovery, ldap, subscription) are available in the Pro Edition.
One of them will be coming soon to the CE (mfa).
CE. Sorry then, I was thinking recovery settings for admin will be available for all editions.
