Good Morning
I am installing passbolt for the first time and used the passbolt_ce_centos_installer.sh script.
Server operating system name and version Centos 7.6.1810
Web server name and version nginx 1.12.2-2.el7
Database server name and version mariadb 5.5.60-1.el7_5
Php version PHP 7.2.13
Passbolt version 2.5.0
It just stays on this screen and does not complete.
I have not been able to reproduce your issue using the latest centos fresh downloaded. Also, the logs you kindly provided do not show any specifics on the problem.
Maybe the output of the healthcheck script could be helpful:
su -c "/var/www/passbolt/bin/cake passbolt healthcheck" -s /bin/bash nginx
This is the result of running the script:
Healthcheck shell…Exception: SQLSTATE[HY000] [1045] Access denied for user ‘’@‘localhost’ (using password: NO) in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Driver/PDODriverTrait.php, line 48]
I can see it is not happy with the mysql login details. Where do i enter these so the script can continue? I have entered the details on the page as requested by the installation script.
Hi
This is very frustrating. I have now tried to reinstall passbolt using the script 4 times and each time the same result.
I have now also tried to install using the src version and it has now stopped at this point:
PHP Warning: Use of undefined constant yes - assumed ‘yes’ (this will throw an Error in a future version of PHP) in /var/www/passbolt/config/passbolt.php on line 68
