Hello
I have logged an issue on Centos 7 where the installation gets stuck on step 7.
I have since installed a new Centos 7 minimal install and recorded all of the output.
There are a few issues.
- WARNING: channel “pecl.php.net” has updated its protocols, use “pecl channel-update pecl.php.net” to update
- ./passbolt_ce_centos_installer.sh: line 926: certbot: command not found
WARNING: Unable to setup SSL using lets encrypt. Please check the install.log
============================================================================= - grep: /var/spool/cron//*: No such file or directory
- libsemanage.dbase_llist_query: could not query record value (No such file or directory).
Collectively these errors make step 7 just spin around as I have now followed word for word the installation instructions and there are a few issues. I will try and work through these. I reckon the next step is to do the same with the source installation which I have also had problems with.
How can I attache a text file with the output from my installation for you?
