Hey all,
So recently we had a hypervisor fail, and thus caused our Passbolt server to crash. It came backup, the Passbolt server, with no issues.
However, now when trying to login, we are getting “An internal error has occurred” after entering our passwords.
From the logs, we can see the following in the error.log file.
2020-03-27 10:22:52 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/auth/is-authenticated.json” could not be found.
2020-03-27 10:22:57 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/auth/is-authenticated.json” could not be found.
2020-03-27 11:10:11 Error: [Exception] encrypt-sign failed
Request URL: /auth/login.json?api-version=v1
2020-03-27 11:13:02 Error: [Exception] encrypt-sign failed
No other errors can be found at present, all keys are valid. I have tried performing an account recovery, and still the same problem.
This would most likely point to an issue with the server key and/or keyring. The server public key could be expired, or not in the keyring, or the file permission on the gnupg keyring could be not be set properly, or SE Linux policy have changed, etc.
[PASS] PHP version 7.0.33-0ubuntu0.16.04.9.
[PASS] Full base url is set to https://passwords.takeshi.nz
[PASS] 19 tables found
[FAIL] The server public key defined in the config/passbolt.php is not in the keyring
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c "gpg --home /var/www/.gnupg --import /opt/passbolt/config/gpg/noexpire.key" www-data
[FAIL] This installation is not up to date. Currently using 2.0.7 and it should be v2.12.0.
Actually, ran healthcheck using sudo and now all is well?
You should run the healthcheck using the webserver user:
sudo su -s /bin/bash -c "/var/www/passbolt/bin/cake passbolt healthcheck" www-data
All keyring operations should be done with this user, and also by providing your keyring location defined in your passbolt.php config (unless it’s using the default one, e.g. /var/www/ on debian).
Keyring permissions should look something like that
drwxrwx--- 9 www-data www-data 4096 Oct 30 06:52 ..
-rw-r--r-- 1 www-data www-data 25 Nov 26 13:18 .#lk0x0000559aa53ea6b0.passbolt.test.3153
drwx------ 2 www-data www-data 4096 Dec 5 14:45 private-keys-v1.d
-rw-r--r-- 1 www-data www-data 63112 Dec 18 11:30 pubring.kbx
-rw-r--r-- 1 www-data www-data 61789 Dec 6 12:29 pubring.kbx~
-rwx------ 1 www-data www-data 600 Mar 24 19:08 random_seed
-rw-r--r-- 1 www-data www-data 49152 Nov 26 13:24 tofu.db
-rwx------ 1 www-data www-data 1200 Oct 30 07:03 trustdb.gpg
Too lax permissions would trigger gnugp to refuse to do some operations (like signing).
Is it possible for you to migrate to the last version? It will be harder to debug as you’re running a version that is almost 2 year old. (some work have been done on the auth / gnupg integration part since then)
Request URL: /healthcheck/
2020-03-27 11:58:02 Error: [Cake\Database\Exception] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'passbolt.actions' doesn't exist (/opt/passbolt/vendor/cakephp/cakephp/src/Database/Schema/Collection.php:132)
Caused by: [PDOException] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'passbolt.actions' doesn't exist (/opt/passbolt/vendor/cakephp/cakephp/src/Database/Statement/MysqlStatement.php:38)
2020-03-27 12:00:28 Error: [Cake\Core\Exception\Exception] Could not use the key to sign and encrypt.encrypt-sign failed (/opt/passbolt/src/Utility/OpenPGP/Backends/Gnupg.php:508)
