I you use a pretty long password, revealing it by clicking the “eye” icon, in the “Edit” window, never shows the complete password, even if you move the cursor to the end. Looks like the end of the password is hidden behind the 3 digits and color rectangle (anti spoof mechanism). You can copy it though, but it’s not possible to just see it, to review or double-check it for example…
Using Passbolt 2.0.1 on CentOS 7 (centos-release-7-4.1708.el7.centos.x86_64). Components are nginx, php7, mariaDB.
Healthcheck report:
// _,///.__/__//_/
[PASS] PHP version 7.0.27.
[PASS] Full base url is set to xhttps://xxxxxx.com
error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
fopen(xhttps://xxxxxx.com/healthcheck/status.json): failed to open stream: operation failed
[PASS] 18 tables found
[FAIL] This installation is not up to date. Currently using 2.0.1 and it should be v2.0.3.
