Problem with password edition after sharing "Could not validate resource data"
System: CentOS 7
Web-server: nginx/1.20.1
Passbolt version: 3.2.1
Plagin version: 3.6.1
Database version: 5.5.68-MariaDB
PHP version: 7.3.30
Some time ago users get this error-message, when try to “Edit” some shared resources, even if they have permissions to.
Healthcheck
[PASS] PHP version 7.3.30.
[PASS] Full base url is set to https://pman.cyberhull.com
[PASS] 25 tables found
[FAIL] This installation is not up to date. Currently using 3.2.1 and it should be v3.6.0.
Hi @Alexander_Lobanov :wave:
Maybe can you try to execute a cleanup:
sudo su -s /bin/bash -c "/var/www/passbolt/passbolt/bin/cake passbolt cleanup" nginx
Can you share its output ? And maybe clear the cache:
sudo su -s /bin/bash -c "/var/www/passbolt/passbolt/bin/cake cache clear_all" nginx
Can you also give us the output of this command:
sudo /var/www/passbolt/bin/status-report nginx
Placed output under spoiler, deleted IPs and prefix of # in shell
[spolier]
sudo su -s /bin/bash -c “/var/www/passbolt/bin/cake passbolt cleanup” nginx
Cleanup shell (fix mode)
sudo su -s /bin/bash -c “/var/www/passbolt/bin/cake cache clear_all” nginx
Clearing default
Cleared default cache
Clearing cake_core
Cleared cake_core cache
Clearing cake_model
Cleared cake_model cache
/ _
//./_//__/
Passbolt CE 3.2.1
Cakephp 4.2.4
Linux pman.cyberhull.com 3.10.0-1160.41.1.el7.x86_64 #1 SMP Tue Aug 31 14:52:47 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
PHP 7.3.30 (cli) (built: Aug 24 2021 10:03:17) ( NTS )
mysql Ver 15.1 Distrib 5.5.68-MariaDB, for Linux (x86_64) using readline 5.1
gpg (GnuPG) 2.0.22
libgcrypt 1.5.3
ERROR: /var/www/passbolt/bin/utils.sh: line 64: composer: command not found
/ _
//./_//__/
[HELP] See.
/ _
//./_//__/
Cleanup shell (dry-run)
/ _
//./_//__/
Data check shell
[PASS] Can validate: 4421/4421
[PASS] Can validate: 2/2
[PASS] Can validate: 8/8
[PASS] Can encrypt: 88/88
[PASS] Can validate: 88/88
[PASS] Can validate: 21/21
[PASS] Can validate: 126/126
[PASS] Can validate: 1185/1185
[PASS] Can validate: 1310/1310
2022-06-03 12:44:35 Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /var/www/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Request URL: /resources.json?api-version=v2
Client IP:
2022-06-03 12:44:36 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/” could not be found. in /var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Request URL: /
Client IP:
2022-06-03 12:46:06 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/” could not be found. in /var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Request URL: /
Client IP:
2022-06-03 12:47:36 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/” could not be found. in /var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Request URL: /
Client IP:
2022-06-03 12:48:03 Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /var/www/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP:
2022-06-03 12:48:04 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/password-generator/settings.json” could not be found. in /var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Request URL: /password-generator/settings.json?api-version=v2
Client IP:
2022-06-03 12:48:19 Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /var/www/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP:
2022-06-03 12:48:58 Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /var/www/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP:
2022-06-03 12:49:06 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/” could not be found. in /var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Request URL: /
Client IP:
2022-06-03 12:49:42 Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /var/www/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP:
2022-06-03 12:49:43 Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /var/www/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP:
2022-06-03 12:49:51 Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /var/www/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP:
2022-06-03 12:50:10 Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /var/www/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP:
2022-06-03 12:50:36 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/” could not be found. in /var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Request URL: /
Client IP:
2022-06-03 12:52:06 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/” could not be found. in /var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Request URL: /
Client IP:
2022-06-03 12:53:36 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/” could not be found. in /var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Request URL: /
Client IP:
2022-06-03 12:54:17 Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /var/www/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP:
Client IP:
2022-06-03 12:55:02 Error: [Authentication\Authenticator\UnauthenticatedException] Authentication is required to continue in /var/www/passbolt/vendor/cakephp/authentication/src/Controller/Component/AuthenticationComponent.php on line 177
Client IP:
2022-06-03 12:55:06 Error: [Cake\Routing\Exception\MissingRouteException] A route matching “/” could not be found. in /var/www/passbolt/vendor/cakephp/cakephp/src/Routing/RouteCollection.php on line 199
Request URL: /
Client IP: [/spoiler]
@Alexander_Lobanov Is it possible the db was modified manually for some reason? The error is because the resource modification during the edit action requires preparing it for all the users who have access to it… but the secret for a particular user is not available. The secret would be in the db already.
For the particular resources being edited that throws the error, can you tell if it is related to one particular user? It seems there is a user who was granted access to the resource and the app still sees they have access from a permissions standpoint, but their secret is missing.
Are any user accounts in general experiencing trouble with access? Any other issues that might be related to this?
Without getting into the db, I might create a new resource (password) and then share it with the same people as the one which is having a problem and see if that works. Then I would try to edit it. If I can, then I might use this one going forward and get rid of the one that’s not working as deleting a resource may not be problematic like when editing it. Trying things like this will help.
Depending on the number of resources and users you have this may not be a practical overall fix but would help to narrow down the issue and what to look for in the db if a manual fix is needed.
Well, different users got this problem. Sometimes it appears, sometimes - not. So issue isnt systematic. We didnt modify db manually, even didn`t update version of service since installation.
@Alexander_Lobanov If I understand correctly you are saying you are not able to consistently reproduce the problem, but it happens more randomly. How many people might be sharing the resource? How are the resources (ram, cpu) for the server? Are you having any other issues like timeouts?
As additional infos, can you check if you have duplicated secrets in your database:
SELECT s.resource_id, s.user_id, min(s.modified) as min_modified
FROM secrets s
GROUP BY s.user_id, s.resource_id
HAVING count(*) > 1
Can you also check the permissions for deleted users ?
select *
from permissions p
where p.aro_foreign_key IN (
    select u.id
    from users u
    where u.deleted = 1
       OR u.active = 0
Best regards,
Database changed
MariaDB > SELECT s.resource_id, s.user_id, min(s.modified) as min_modified
ERROR 1109 (42S02): Unknown table ‘s’ in field list
→ FROM secrets s
→ GROUP BY s.user_id, s.resource_id
→ HAVING count(*) > 1;
Empty set (0.02 sec)
MariaDB > select *
→ from permissions p
→ where p.aro_foreign_key IN (
→ select u.id
→ from users u
→ where u.deleted = 1
→ OR u.active = 0
Empty set (0.00 sec)
MariaDB >
No other serious issues at all. Resources are enough for working and no timeouts.
We have near 100 Users and any of them have about 4-5 passwords or near it
About sharing: i cant say exactly - how many people participate in sharing. Sometimes they are people, sometimes groups, I didnt look at this properly.
same problem at my system - did you solve your problem?
Hi @grufo Can you share more about what you confirmed in your case given the above steps?
Are you running an updated version? This is a rarely seen error.
hi @garrett, I just added a new forum post:
https://community.passbolt.com/t/400-the-secrets-of-all-the-users-having-access-to-the-resource-are-required/7637
with more details!
Well, we updated to another system and to latest version and problem was solved.
Maybe it was bcs of our developer`s “fix” of hiding “User” tab. With new DMARC it is not needed.
