Users page not accessible
Hello everyone!
We’re currently using Passbolt CE 4.9.1/Cakephp 4.5.2 on an Ubuntu 22.04.5 machine. Installed via package manager (Install Passbolt on Ubuntu 24.04 | Passbolt documentation.)
The issue we are facing is that the Users page is inaccessible / no users are shown.
It appeared as soon as we created a third user, no problems arose when we only had 2 users.
The server is currently running on 2 cores / 3gb RAM. Disk is about 60% full.
Server is behind an NPMPlus Reverse Proxy. Shouldn’t matter as it worked with the reverse proxy before, after we created a third user, problem arose.
I’ve already done all these steps:
  • Healthcheck (will provide in comment)
  • passbolt cleanup (no issue was found, data seems squeaky clean!)
  • Restart server
  • Reinstalled passbolt plugin, tried on 3 browsers (Edge w/ Edge plugin, Edge w/ Chrome plugin, Chrome, Firefox), tried on 3 different machines (same behavior)
  • Enabled debug mode in Chrome Plugins and got following responses when trying to access Users page: (will add in another comment)
  • Checked error.log - will also add in comment
I cannot find anything else regarding this issue and am at the end of my wits.
The error is reproducable by restoring an older Backup of the machine and creating a new user.
I’d be grateful for any pointers.
I’m a bit rusty in my Ubuntu administration, so please try to keep it ELI5 (figuratively!)
Best regards,
Stefan
Health check:
[PASS] PHP version 8.1.2-1ubuntu2.18.
[PASS] Full base url is set to https://XXXX (edited out)
SMTP settings
[HELP] You can try:
[PASS] 31 tables found.
Data Integrity:
Too long to post here. But every check passes.
Cleanup:
Cleanup shell (fix mode)
Chrome Debug Log:
index.js:2 Error: The user is not set
at ee.get (index.js:2:30088)
at Ro.get (index.js:2:226545)
at index.js:2:227271
updateSuggestedResourcesBadge @ index.js:2
index.js:2 PassboltBadResponseError: An internal error occurred. The server response could not be parsed. Please contact your administrator.
at ze.parseResponseJson (index.js:2:39721)
at async Rs.findAll (index.js:2:136374)
at async Ao.findAll (index.js:2:225117)
at async Ao.updateLocalStorage (index.js:2:224550)
at async Op.exec (index.js:2:438030)
at async Op._exec (index.js:2:437876)
at async f. (index.js:2:440359)
_exec @ index.js:2
app.js:2 Uncaught (in promise) {stack: ‘PassboltBadResponseError: An internal error occurr…hjepacocaffmoppf/serviceWorker/index.js:2:440359)’, message: ‘An internal error occurred. The server response co…not be parsed. Please contact your administrator.’, name: ‘PassboltBadResponseError’}message: "An internal error occurred. The server response could not be parsed. Please contact your administrator."name: "PassboltBadResponseError"stack: “PassboltBadResponseError: An internal error occurred. The server response could not be parsed. Please contact your administrator.\n at ze.parseResponseJson (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:39721)\n at async Rs.findAll (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:136374)\n at async Ao.findAll (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:225117)\n at async Ao.updateLocalStorage (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:224550)\n at async Op.exec (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:438030)\n at async Op._exec (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:437876)\n at async f. (chrome-extension://didegimhafipceonhjepacocaffmoppf/serviceWorker/index.js:2:440359)”[[Prototype]]: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()defineGetter: ƒ defineGetter()defineSetter: ƒ defineSetter()lookupGetter: ƒ lookupGetter()lookupSetter: ƒ lookupSetter()proto: (…)get proto: ƒ proto()set proto: ƒ proto()
(anonymous) @ app.js:2
_onMessage @ app.js:2
Thanks!
Same Problem here: PB-34421 - App/users page not load - #14 by max
Ive have a similar Setup like you and the same problem …
Hey @stefanh and @antony
Ive got it working - ive checked if the language is right set, because some other user said that for him it was set to english, but its showed on german.
So ive checked it on my user and yes, the setting was also in my User on onglish, so ive changed it to german, testes the “Users” or “Benutzer” Page and boom it works :slight_smile:
Or was it fixed with the Update of the Browser Extension on 03.10.?
Ive canceled or meeting for tomorrow @antony i think its solved for now :slight_smile:
