Oracle Linux 8.7 fresh server
Followed instructions for Oracle Linux 8
[root@passbolt passbolt]# sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck" ngi
[PASS] PHP version 8.1.16.
[PASS] Full base url is set to https://passbolt.regoonline.com
[PASS] 26 tables found
[PASS] The server public key defined in the /etc/passbolt/passbolt.php (or environment variables) is in the
[PASS] Using latest passbolt version (3.11.0).
[PASS] The Self Registration plugin is enabled.
SMTP Settings
The issue is, when I go to my “administration” page, there is only MFA options, I have no other Administration options. Nothing for email notifications or anything else.
What do these mean and how do I resolve?
Thanks!
