I followed the instruction on deploying this using default values but the passbolt deployment pod just stays stuck in pending. The init sidecar container seems to keep “waiting to connect to a database” but it doesn’t even though the maria-db and redis cluster is up.
I followed these instructions: Installing passbolt with Helm | Kubernetes | passbolt
side note: I did not set any values for email as I just want to get this up first. I’m not sure if email has to be set in values for the deployment pod to start.
Kubernetes version: 1.24.13
This a fresh install on my EKS cluster. I can reproduce this every time I uninstall and redeploy.
@johnson-huynh welcome to the forum!
Since you mention using default values did you go through and change all of the CHANGEME fields?
Additionally which all pods are running currently?
Hi @clayton!
I did when I deployed it the first time. The pods ran for maria-db and redis but the passbolt deply server pods were stuck in pending state. The init container logs just shows “waiting for database connection” even though the database pods were running.
I ended up just uninstalling and redeploying again leaving the CHANGEME values as is and received the same results.
Here is some deployment info to the passbolt deployment:
Namespace: default
CreationTimestamp: Mon, 12 Jun 2023 17:56:24 -0500
Labels: app.kubernetes.io/action=srv
app.kubernetes.io/instance=mypassbolt
app.kubernetes.io/managed-by=Helm
app.kubernetes.io/name=passbolt
app.kubernetes.io/type=depl
app.kubernetes.io/version=4.0.0-2-ce
helm.sh/chart=passbolt-0.3.2
Annotations: deployment.kubernetes.io/revision: 1
meta.helm.sh/release-name: mypassbolt
meta.helm.sh/release-namespace: default
Selector: app.kubernetes.io/instance=mypassbolt,app.kubernetes.io/name=passbolt,app.kubernetes.io/type notin (cron,job)
Replicas: 2 desired | 2 updated | 2 total | 0 available | 2 unavailable
StrategyType: RollingUpdate
MinReadySeconds: 0
RollingUpdateStrategy: 25% max unavailable, 25% max surge
Pod Template:
Labels: app.kubernetes.io/instance=mypassbolt
Annotations: checksum/cm-env: a835c3e7c316adc22a194561741001176409abc05ba3a94149d4b7758a5c9baf
checksum/sec-env: a9076b32888a1b6e41f5cb628d68867de1e7e7aef5ea26369e5b36c477e64e5f
checksum/sec-gpg: c227af8051a503af939932719c196383bb9288eec02a31a5df25d8c4fd3f12c7
checksum/sec-jwt: 2f41f5633f80dd2504aa5868336c5a0016af810da0c0e0abc8e3c531b2aca3c4
checksum/sec-redis-proxy: 7c4521bdc515549da22421dc7b425295dc3dbdd055751da9511e12889e828f08
Service Account: mypassbolt-sa-common
Init Containers:
mypassbolt-depl-srv-init:
Image: mariadb:latest
Port: <none>
Host Port: <none>
Command:
/bin/bash
Args:
-c
cat <<-EOF > /tmp/defaultsfile.cnf
[client]
user=${DATASOURCES_DEFAULT_USERNAME}
password=${DATASOURCES_DEFAULT_PASSWORD}
host=${DATASOURCES_DEFAULT_HOST}
connect-timeout=2
EOF
userhost="%"
while ! mysql --defaults-file=/tmp/defaultsfile.cnf -e "SELECT 1" > /dev/null 2>&1; do
echo "Waiting for database connection..."
sleep 2
done
Environment Variables from:
mypassbolt-cm-env ConfigMap Optional: false
mypassbolt-sec-env Secret Optional: false
Environment:
DATASOURCES_DEFAULT_HOST: mypassbolt-mariadb-primary
Mounts: <none>
Containers:
mypassbolt-depl-srv:
Image: passbolt/passbolt:4.0.0-2-ce
Ports: 443/TCP, 80/TCP
Host Ports: 0/TCP, 0/TCP
Command:
/bin/bash
Args:
-c
set -e
> /etc/supervisor/conf.d/cron.conf
/docker-entrypoint.sh
Liveness: http-get https://:https/healthcheck/status.json delay=20s timeout=1s period=10s #success=1 #failure=3
Readiness: http-get https://:https/healthcheck/status.json delay=5s timeout=1s period=10s #success=1 #failure=3
Environment:
Mounts:
/etc/passbolt/app.php from mypassbolt-cm-app-php (ro,path="app.php")
/etc/passbolt/gpg from mypassbolt-depl-srv-sec-gpg (ro)
/etc/passbolt/jwt from mypassbolt-depl-srv-sec-jwt (ro)
/etc/ssl/certs/passbolt from mypassbolt-depl-srv-sec-tls (ro)
mypassbolt-depl-srv-redisproxy:
Image: haproxy:latest
Port: <none>
Host Port: <none>
Environment: <none>
Mounts:
/usr/local/etc/haproxy/haproxy.cfg from mypassbolt-depl-srv-sec-redis-proxy (ro,path="haproxy.cfg")
Volumes:
mypassbolt-depl-srv-sec-tls:
Type: Secret (a volume populated by a Secret)
SecretName: mypassbolt-sec-tls
Optional: false
mypassbolt-depl-srv-sec-gpg:
SecretName: mypassbolt-sec-gpg
Optional: false
mypassbolt-cm-app-php:
Type: ConfigMap (a volume populated by a ConfigMap)
Optional: false
mypassbolt-depl-srv-sec-jwt:
SecretName: mypassbolt-sec-jwt
Optional: false
mypassbolt-depl-srv-sec-redis-proxy:
SecretName: mypassbolt-sec-redis-proxy
Optional: false
Conditions:
Type Status Reason
Available False MinimumReplicasUnavailable
Progressing True ReplicaSetUpdated
OldReplicaSets: <none>
NewReplicaSet: mypassbolt-depl-srv-54576658c6 (2/2 replicas created)
Events:
Type Reason Age From Message
Normal ScalingReplicaSet 35m deployment-controller Scaled up replica set mypassbolt-depl-srv-54576658c6 to 2
Mariadb logs:
mariadb 22:58:58.69 INFO ==> ** Starting MariaDB **
2023-06-12 22:58:58 0 [Note] Starting MariaDB 10.6.12-MariaDB-log source revision 4c79e15cc3716f69c044d4287ad2160da8101cdc as process 1
2023-06-12 22:58:58 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-06-12 22:58:58 0 [Note] InnoDB: Number of pools: 1
2023-06-12 22:58:58 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-06-12 22:58:58 0 [Note] mysqld: O_TMPFILE is not supported on /opt/bitnami/mariadb/tmp (disabling future attempts)
2023-06-12 22:58:58 0 [Note] InnoDB: Using Linux native AIO
2023-06-12 22:58:58 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
2023-06-12 22:58:58 0 [Note] InnoDB: Completed initialization of buffer pool
2023-06-12 22:58:59 0 [Note] InnoDB: 128 rollback segments are active.
2023-06-12 22:58:59 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-06-12 22:58:59 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-06-12 22:59:24 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2023-06-12 22:59:24 0 [Note] InnoDB: 10.6.12 started; log sequence number 42204; transaction id 14
2023-06-12 22:59:24 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-06-12 22:59:24 0 [Note] InnoDB: Loading buffer pool(s) from /bitnami/mariadb/data/ib_buffer_pool
2023-06-12 22:59:24 0 [Note] InnoDB: Buffer pool(s) load completed at 230612 22:59:24
2023-06-12 22:59:24 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-06-12 22:59:24 0 [Note] Server socket created on IP: '::'.
2023-06-12 22:59:24 0 [Warning] 'proxies_priv' entry '@% root@mypassbolt-mariadb-primary-0' ignored in --skip-name-resolve mode.
2023-06-12 22:59:25 0 [Note] /opt/bitnami/mariadb/sbin/mysqld: ready for connections.
Version: '10.6.12-MariaDB-log' socket: '/opt/bitnami/mariadb/tmp/mysql.sock' port: 3306 Source distribution
2023-06-12 23:00:09 9 [Note] Start binlog_dump to slave_server(338), pos(, 4), using_gtid(0), gtid('')
This is resolved now!
Mariadb container latest image doesn’t have the mysql client that is used for check the database connection in the init container. I ended up changing the default chart values to:
app:
initImage:
repository: bitnami/mariadb
@vasconce1o the post got hung up for approval, sorry about that. Thanks for contributing!
