I have been trying to deploy Passbolt on a Rancher environment for a few days now, but it is not deploying correctly.
Rancher Version: v2.7.1
Kubernetes Version: v1.24.9 for my cluster
Passbolt Version: v0.3.2
Therefore, I am using the deployment method with Helm : https://help.passbolt.com/hosting/install/ce/helm.html
I have obtained the repository :
Now comes the moment of deploying Passbolt. Here is my YAML file for the deployment with modified values of CHANGEME:
affinity: {}
app:
cache:
redis:
enabled: true
sentinelProxy:
enabled: true
image:
repository: haproxy
tag: latest
image:
pullPolicy: IfNotPresent
repository: passbolt/passbolt
tag: 4.0.0-2-ce
initImage:
repository: mariadb
tag: latest
resources: {}
autoscaling:
enabled: false
maxReplicas: 100
minReplicas: 1
targetCPUUtilizationPercentage: 80
cronJobEmail:
enabled: true
schedule: '* * * * *'
fullnameOverride: ''
gpgPath: /etc/passbolt/gpg
gpgServerKeyPrivate: ''
gpgServerKeyPublic: ''
imagePullSecrets: []
ingress:
annotations: {}
enabled: false
hosts:
- host: passbolt.local
paths:
- path: /
pathType: ImplementationSpecific
tls:
- hosts:
- passbolt.local
secretName: tls
jwtPath: /etc/passbolt/jwt
jwtServerPrivate: null
jwtServerPublic: null
livenessProbe:
httpGet:
httpHeaders:
- name: Host
value: passbolt.local
path: /healthcheck/status.json
port: https
scheme: HTTPS
initialDelaySeconds: 20
periodSeconds: 10
mariadb:
architecture: replication
auth:
database: passbolt
password: test1
replicationPassword: test1
rootPassword: root
username: admin
primary:
persistence:
accessModes:
- ReadWriteOnce
annotations: {}
enabled: true
existingClaim: ''
labels: {}
selector: {}
storageClass: ''
subPath: ''
secondary:
persistence:
accessModes:
- ReadWriteOnce
annotations: {}
enabled: true
labels: {}
selector: {}
storageClass: ''
subPath: ''
mariadbDependencyEnabled: true
nameOverride: ''
networkPolicy:
enabled: false
label: app.kubernetes.io/name
namespaceLabel: ingress-nginx
podLabel: ingress-nginx
nodeSelector: {}
passboltEnv:
plain:
APP_FULL_BASE_URL: https://passbolt.local
CACHE_CAKE_DEFAULT_SERVER: 127.0.0.1
DEBUG: false
EMAIL_DEFAULT_FROM: no-reply@passbolt.local
EMAIL_TRANSPORT_DEFAULT_HOST: 127.0.0.1
KUBECTL_DOWNLOAD_CMD: >-
curl -LO "https://dl.k8s.io/release/$(curl -L -s
https://dl.k8s.io/release/stable.txt)/bin/linux/amd64/kubectl"
PASSBOLT_JWT_SERVER_KEY: /var/www/passbolt/config/jwt/jwt.key
PASSBOLT_JWT_SERVER_PEM: /var/www/passbolt/config/jwt/jwt.pem
PASSBOLT_KEY_EMAIL: passbolt@yourdomain.com
PASSBOLT_LEGAL_PRIVACYPOLICYURL: https://www.passbolt.com/privacy
PASSBOLT_PLUGINS_JWT_AUTHENTICATION_ENABLED: true
PASSBOLT_PLUGINS_LICENSE_LICENSE: /etc/passbolt/subscription_key.txt
PASSBOLT_REGISTRATION_PUBLIC: true
PASSBOLT_SELENIUM_ACTIVE: false
PASSBOLT_SSL_FORCE: true
secret:
CACHE_CAKE_DEFAULT_PASSWORD: test123
DATASOURCES_DEFAULT_DATABASE: passbolt
DATASOURCES_DEFAULT_PASSWORD: test1
DATASOURCES_DEFAULT_USERNAME: admin
EMAIL_TRANSPORT_DEFAULT_PASSWORD: test1
EMAIL_TRANSPORT_DEFAULT_USERNAME: admin
podAnnotations: {}
podSecurityContext: {}
rbacEnabled: true
readinessProbe:
httpGet:
httpHeaders:
- name: Host
port: https
scheme: HTTPS
initialDelaySeconds: 5
periodSeconds: 10
redis:
auth:
enabled: true
password: test2
sentinel:
enabled: true
redisDependencyEnabled: true
replicaCount: 2
service:
annotations: {}
port: 443
targetPort: 443
type: ClusterIP
serviceAccount:
annotations: {}
create: true
tolerations: []
global:
cattle:
systemProjectId: p-8cxg9
After a few seconds, I receive this error message repeatedly:
Creating 25 resource(s)
Beginning wait for 25 resources with a timeout of 10m0s
Deployment is not ready: default/testpassbolt-depl-srv. 0 out of 2 expected pods are ready
At the end of the 10 minutes, I check the different created pods and I can see that some are not deploying correctly:
Here are the various tutorials used to resolve this issue, but without success:
https://community.passbolt.com/t/helm-installation-issue/7721
Hey @Thomas4 welcome to the forum. This issue looks pretty similar to another we recently had here. Could you check that out and see if it works for you as well?
Hey @clayton
Yes, I have already tried this solution, but it still doesnât work.
affinity: {}
app:
cache:
redis:
enabled: true
sentinelProxy:
enabled: true
image:
repository: haproxy
tag: latest
image:
tag: 4.0.0-2-ce
initImage:
repository: bitnami/mariadb
tag: latest
resources: {}
autoscaling:
enabled: false
maxReplicas: 100
minReplicas: 1
Some pods fail to deploy.
diego
June 15, 2023, 8:22am
4
this is fixed in develop of the charts-passbolt repo, we will make the version available most likely today PB-25026: fixes #26 ¡ passbolt/charts-passbolt@e83cfbe ¡ GitHub
diego
June 15, 2023, 9:33am
5
We have just published the new helm chart version, let us know if you find any issues
Still unable to deploy some pods
diego
June 15, 2023, 11:52am
7
We would need the logs on the init pod. Are you sure you updated the chart to the latest version? And do you have the latest values.yaml from the chart repo updated too?
Yes I have the latest chart version
Logs : passbolttest-mariadb-primary-0
root@rancher-noeud2:~# docker logs 466a947156dc
mariadb 11:37:08.36
mariadb 11:37:08.40 Welcome to the Bitnami mariadb container
mariadb 11:37:08.42 Subscribe to project updates by watching https://github.com/bitnami/containers
mariadb 11:37:08.44 Submit issues and feature requests at https://github.com/bitnami/containers/issues
mariadb 11:37:08.45
mariadb 11:37:08.46 INFO ==> ** Starting MariaDB setup **
mariadb 11:37:08.72 INFO ==> Validating settings in MYSQL_*/MARIADB_* env vars
mariadb 11:37:08.92 INFO ==> Initializing mariadb database
mariadb 11:37:08.98 WARN ==> The mariadb configuration file '/opt/bitnami/mariadb/conf/my.cnf' is not writable. Configurations based on environment variables will not be applied for this file.
mariadb 11:37:08.99 INFO ==> Installing database
2023-06-15 11:37:12 1 [Warning] Failed to load slave replication state from table mysql.gtid_slave_pos: 1017: Can't find file: './mysql/' (errno: 2 "No such file or directory")
mariadb 11:37:23.11 INFO ==> Starting mariadb in background
2023-06-15 11:37:23 0 [Note] Starting MariaDB 10.6.12-MariaDB-log source revision 4c79e15cc3716f69c044d4287ad2160da8101cdc as process 100
2023-06-15 11:37:23 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-06-15 11:37:23 0 [Note] InnoDB: Using transactional memory
2023-06-15 11:37:23 0 [Note] InnoDB: Number of pools: 1
2023-06-15 11:37:23 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-06-15 11:37:23 0 [Note] mysqld: O_TMPFILE is not supported on /opt/bitnami/mariadb/tmp (disabling future attempts)
2023-06-15 11:37:23 0 [Note] InnoDB: Using Linux native AIO
2023-06-15 11:37:23 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
2023-06-15 11:37:23 0 [Note] InnoDB: Completed initialization of buffer pool
2023-06-15 11:37:24 0 [Note] InnoDB: 128 rollback segments are active.
2023-06-15 11:37:24 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-06-15 11:37:24 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-06-15 11:37:24 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2023-06-15 11:37:24 0 [Note] InnoDB: 10.6.12 started; log sequence number 42132; transaction id 14
2023-06-15 11:37:24 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-06-15 11:37:24 0 [Note] InnoDB: Loading buffer pool(s) from /bitnami/mariadb/data/ib_buffer_pool
2023-06-15 11:37:24 0 [Note] InnoDB: Buffer pool(s) load completed at 230615 11:37:24
2023-06-15 11:37:24 0 [Note] Server socket created on IP: '127.0.0.1'.
2023-06-15 11:37:25 0 [Warning] 'user' entry 'root@passbolttest-mariadb-primary-0' ignored in --skip-name-resolve mode.
2023-06-15 11:37:25 0 [Warning] 'user' entry '@passbolttest-mariadb-primary-0' ignored in --skip-name-resolve mode.
2023-06-15 11:37:25 0 [Warning] 'proxies_priv' entry '@% root@passbolttest-mariadb-primary-0' ignored in --skip-name-resolve mode.
2023-06-15 11:37:25 0 [Note] /opt/bitnami/mariadb/sbin/mysqld: ready for connections.
Version: '10.6.12-MariaDB-log' socket: '/opt/bitnami/mariadb/tmp/mysql.sock' port: 3306 Source distribution
mariadb 11:37:25.57 INFO ==> Configuring authentication
2023-06-15 11:37:25 7 [Warning] 'proxies_priv' entry '@% root@passbolttest-mariadb-primary-0' ignored in --skip-name-resolve mode.
mariadb 11:37:26.51 INFO ==> Configuring replication in master node
2023-06-15 11:37:26 14 [Warning] 'proxies_priv' entry '@% root@passbolttest-mariadb-primary-0' ignored in --skip-name-resolve mode.
mariadb 11:37:26.83 INFO ==> Running mysql_upgrade
find: '/docker-entrypoint-startdb.d/': No such file or directory
mariadb 11:37:27.89 INFO ==> Stopping mariadb
2023-06-15 11:37:27 0 [Note] /opt/bitnami/mariadb/sbin/mysqld (initiated by: unknown): Normal shutdown
2023-06-15 11:37:27 0 [Note] InnoDB: FTS optimize thread exiting.
2023-06-15 11:37:28 0 [Note] InnoDB: Starting shutdown...
2023-06-15 11:37:28 0 [Note] InnoDB: Dumping buffer pool(s) to /bitnami/mariadb/data/ib_buffer_pool
2023-06-15 11:37:28 0 [Note] InnoDB: Buffer pool(s) dump completed at 230615 11:37:28
2023-06-15 11:37:28 0 [Note] InnoDB: Removed temporary tablespace data file: "./ibtmp1"
2023-06-15 11:37:28 0 [Note] InnoDB: Shutdown completed; log sequence number 42144; transaction id 15
2023-06-15 11:37:28 0 [Note] /opt/bitnami/mariadb/sbin/mysqld: Shutdown complete
mariadb 11:37:29.20 INFO ==> ** MariaDB setup finished! **
mariadb 11:37:31.00 INFO ==> ** Starting MariaDB **
2023-06-15 11:37:31 0 [Note] Starting MariaDB 10.6.12-MariaDB-log source revision 4c79e15cc3716f69c044d4287ad2160da8101cdc as process 1
2023-06-15 11:37:31 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-06-15 11:37:31 0 [Note] InnoDB: Using transactional memory
2023-06-15 11:37:31 0 [Note] InnoDB: Number of pools: 1
2023-06-15 11:37:31 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2023-06-15 11:37:31 0 [Note] mysqld: O_TMPFILE is not supported on /opt/bitnami/mariadb/tmp (disabling future attempts)
2023-06-15 11:37:31 0 [Note] InnoDB: Using Linux native AIO
2023-06-15 11:37:31 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
2023-06-15 11:37:31 0 [Note] InnoDB: Completed initialization of buffer pool
2023-06-15 11:37:32 0 [Note] InnoDB: 128 rollback segments are active.
2023-06-15 11:37:32 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-06-15 11:37:32 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-06-15 11:37:32 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2023-06-15 11:37:32 0 [Note] InnoDB: 10.6.12 started; log sequence number 42144; transaction id 14
2023-06-15 11:37:32 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-06-15 11:37:32 0 [Note] InnoDB: Loading buffer pool(s) from /bitnami/mariadb/data/ib_buffer_pool
2023-06-15 11:37:32 0 [Note] InnoDB: Buffer pool(s) load completed at 230615 11:37:32
2023-06-15 11:37:32 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-06-15 11:37:32 0 [Note] Server socket created on IP: '::'.
2023-06-15 11:37:32 0 [Warning] 'proxies_priv' entry '@% root@passbolttest-mariadb-primary-0' ignored in --skip-name-resolve mode.
2023-06-15 11:37:32 0 [Note] /opt/bitnami/mariadb/sbin/mysqld: ready for connections.
2023-06-15 11:37:41 5 [Warning] Access denied for user 'thomas'@'10.42.1.146' (using password: YES)
2023-06-15 11:37:42 6 [Warning] Access denied for user 'thomas'@'10.42.1.149' (using password: YES)
2023-06-15 11:37:42 7 [Warning] Access denied for user 'thomas'@'10.42.1.149' (using password: YES)
2023-06-15 11:37:42 8 [Warning] Access denied for user 'thomas'@'10.42.0.151' (using password: YES)
2023-06-15 11:37:44 9 [Warning] Access denied for user 'thomas'@'10.42.1.146' (using password: YES)
2023-06-15 11:37:44 10 [Warning] Access denied for user 'thomas'@'10.42.0.151' (using password: YES)
2023-06-15 11:37:46 11 [Warning] Access denied for user 'thomas'@'10.42.1.146' (using password: YES)
2023-06-15 11:37:46 12 [Warning] Access denied for user 'thomas'@'10.42.0.151' (using password: YES)
logs : passbolttest-depl-srv-7cc86c944d-t67xs
root@rancher-noeud2:~# docker logs f8040eee6d0c
Waiting for database connection...
diego
June 15, 2023, 1:12pm
9
Those access denied in the mysql container are related with the initdb container using the incorrect password/username? Could you check that?
I tried to redeploy Passbolt with the same database credentials (username and password) for the MySQL database, but it doesnât seem to be working.
Dani
June 15, 2023, 3:31pm
11
Hey! Maybe it is related to the fact that mariadb chart doesnât kill the volumes that creates on a uninstall event. So next time you install it, it will reuse those volumes and their content (also configuration like credentials). To avoid that, uninstall the passbolt helm release, list the Persistentvolumeclaims on the cluster and clean the ones that are related to your installation. For a default installation with a release name âpassboltâ I have these ones:
data-passbolt-mariadb-primary-0
data-passbolt-mariadb-secondary-0
redis-data-passbolt-redis-node-0
redis-data-passbolt-redis-node-1
redis-data-passbolt-redis-node-2
After that try to install it again.
Dani
June 16, 2023, 3:45pm
14
Have you managed to solve it?
Hi, sorry for the late response,
Everything seems to be working fine, the deployment is going smoothly.
Now, I need to access Passbolt. I think Iâll have to create a user or do something else.
Thanks to the Passbolt community for helping me.
Thomas4,
What did you do to resolve this issue? I am seeing the same as you with âaccess denied for userâ no matter what I do. I have uninstalled and cleaned up my namespace, and even deleted and recreated the NS in rancher, but still get the same error.
I know that this thread is old so if I need to create a new thread just let me know.
