SMTP through port 25 without TLS or SSL encryption
I’m trying to migrate a passbolt app running on a docker container with docker-compose to a kubernetes environment.
This is the docker-compose.yml file
version: "2"
  webpass:
    hostname: webpass
    container_name: webpass
    restart: always
    external_links:
        - mysql
      APP_FULL_BASE_URL: https://subdomain.domain.com
      DATASOURCES_DEFAULT_HOST: "database-host"
      DATASOURCES_DEFAULT_USERNAME: "database-user"
      DATASOURCES_DEFAULT_PASSWORD: "database-pass"
      DATASOURCES_DEFAULT_DATABASE: "database-name"
      EMAIL_DEFAULT_FROM_NAME: "From name"
      EMAIL_DEFAULT_FROM: "from@address.com"
      EMAIL_TRANSPORT_DEFAULT_HOST: "our-smpt-host-only-working-through-port-25"
      EMAIL_TRANSPORT_DEFAULT_PORT: 25
      EMAIL_TRANSPORT_DEFAULT_USERNAME: ""
      EMAIL_TRANSPORT_DEFAULT_PASSWORD: ""
    command:
        "/usr/bin/wait-for.sh",
        "-t",
        "0",
        "mysql:3306",
        "/docker-entrypoint.sh",
      - 8081:80
      - 8444:443
  gpg_volume:
  jwt_volume:
networks:
  default:
    external: true
The application is working behind a Nginx reverse proxy.
The version of Passbolt on this docker image is 4.4.2:
root@webpass:/usr/share/php/passbolt# bin/cake passbolt version
Passbolt CE 4.4.2
Cakephp 4.4.17
To migrate this application to kubernetes we have developed a custom helm chart and we can deploy it without problems on kubernetes. The env vars used on kubernetes are next:
env:
  ## passbolt
  PASSBOLT_GPG_SERVER_KEY_FINGERPRINT: "gpg-fingerprint-following-migration-instructions"
  PASSBOLT_KEY_EMAIL: "passbolt@yourdomain.com"
As you can see, SMTP config is simply: plain sents through port 25 and empty user and pass without TLS or SSL encryption. The security is based on IP whitelist.
I followed your migrations instructions Migrate to a new Docker Container | Passbolt documentation. and it seems that everything is working because I can access to web interface but I can not login because system is not sending automatic email
BUT
test emails are been sent without problems:
 Debug email shell
Email configuration
Host: smtp-server
Port: 25
Username:
Password: *********
TLS: false
Sending email from: WebPass <from@address.com>
Sending email to: francisco.galvez-ext@havasit.com
Trace
[220] smtp-25-host Microsoft ESMTP MAIL Service, Version: 10.0.17763.1697 ready at  Thu, 18 Apr 2024 14:54:11 +0200
 EHLO localhost
[250] smtp-25-host Hello [193.111.67.2]
[250] TURN
[250] SIZE 36700160
[250] ETRN
[250] PIPELINING
[250] DSN
[250] ENHANCEDSTATUSCODES
[250] 8bitmime
[250] BINARYMIME
[250] CHUNKING
[250] VRFY
[250] OK
 MAIL FROM:<from@address.com>
[250] 2.1.0 from@address.com....Sender OK
 RCPT TO:<francisco.galvez-ext@havasit.com>
[250] 2.1.5 francisco.galvez-ext@havasit.com
 DATA
[354] Start mail input; end with <CRLF>.<CRLF>
To: francisco.galvez-ext@havasit.com
Date: Thu, 18 Apr 2024 12:53:48 +0000
Message-ID: <825d74470b3b4bf7ba392e7f550093f5@pod-name-passbolt-b45cf96d7-b7r7z>
Subject: Passbolt test email
MIME-Version: 1.0
Congratulations!
[250] 2.6.0  <825d74470b3b4bf7ba392e7f550093f5@ns-pre-es-webpass-deploy-passbolt-b45cf96d7-b7r7z> Queued mail for delivery
 QUIT
When I check my email inbox I can see the email.
BUT
when I try to send pending emails throug console with bin/cake email_queue.sender there is no output. Investigating in database I found the table email_queue where I can see the error:
SMTP authentication method not allowed, check if SMTP server requires TLS.
There is no more info and log file /var/log/passbolt/error.log is empty.
I have read your documentation and your community forum but I do not have found anything useful. All matters are related to TLS or SSL but there is nothing about send email without encryption.
The main pages where I have found related info but not solve my problem are:
  • .com – /docs/admin/emails/email-server/
  • community --/t/email-configuration-needs-clarification-fails-without-username-password/1490
  • community – /t/email-transport-default-tls-seemingly-ignored/2961
  • .com – /docs/hosting/troubleshooting/docker/
  • .com – /docs/hosting/troubleshooting/email/
To finish, this is the output for su -s /bin/bash -c "bin/cake passbolt healthcheck" www-data command:
 [PASS] PHP version 8.2.7.
 [PASS] Full base url is set to https://pre-webpass.havasmedia.com
 [PASS] 31 tables found
 [FAIL] Could not connect to passbolt repository to check versions It is not possible check if your version is up to date.
 SMTP Settings
There are 2 errors but I think they are not related to my problem.
Also, I have investigate the file /etc/passbolt/app.default.php and I have seen all is configured with env vars that have null as default value if they don’t exist.
    'EmailTransport' => [
        'default' => [
             * The keys host, port, timeout, username, password, client and tls
             * are used in SMTP transports
            'host' => env('EMAIL_TRANSPORT_DEFAULT_HOST', 'localhost'),
            'port' => env('EMAIL_TRANSPORT_DEFAULT_PORT', 25),
            'timeout' => env('EMAIL_TRANSPORT_DEFAULT_TIMEOUT', 30),
             * It is recommended to set these options through your environment or passbolt.php
            'username' => env('EMAIL_TRANSPORT_DEFAULT_USERNAME', null),
            'password' => env('EMAIL_TRANSPORT_DEFAULT_PASSWORD', null),
            'client' => env('EMAIL_TRANSPORT_DEFAULT_CLIENT', null),
            'tls' => env('EMAIL_TRANSPORT_DEFAULT_TLS', null),
            'url' => env('EMAIL_TRANSPORT_DEFAULT_URL', null),
        'Debug' => [
            'className' => 'Debug'
I don’t know how to continue debugging. Please, can you tell me how to allow send automatic emails to a smtp server running on port 25 without tls and ssl?
Thanks in advance
Francisco Gálvez
Hello? Is there someone?
Apologies for the delay. Do you have an account that is currently logged into the web UI?
If so can you take a look at the email server settings there just to make sure everything is correct?
Thanks for your response and sorry for my delay (the Murphy’s law). I have login as an admin and this is the config
The config shown has the same value as I defined in kubernetes environment values.
As previous tests when I try to send an email through bin/cake command everything is working well.
It looks like you have the authentication method set to username and password but then left those blank. If you don’t need those could you switch authentication to none and try again?
Bingo! You’re awesome @clayton
I have selected “none” in Authentication method and now emails are been sent.
My problem is solved (thank you) but I think you should homegenize emails sents, it confuses to send email through console test command and not through web interface.
BUT, thank you very much for your help and congratulations for your “Passbolt”
Francisco Gálvez
