Hi everyone,
I’m testing Passbolt on my home server, but I’m running into some issues with SMTP configuration. Here’s a brief overview of my setup:
- Mail Hosting: I use a shared webhost for email.
- DNS: I manage DNS through Cloudflare to update subdomain IPs, directing them to my home lab. For example,
passbolt.domain.compoints to an Nginx Proxy Manager, which redirects traffic to the correct internal port.
The issue arises when I configure SMTP:
- With TLS: Using the TLS port for SMTP results in a timeout.
- Without TLS: SMTP works, and emails are sent successfully.
I suspect the issue may be related to certificates, as the domain mail.domain.com is using a Cloudflare origin certificate.
Could someone please help me troubleshoot this? I’d appreciate any guidance on resolving this issue.
Please see below for all relevant outputs, and the docker-compose file. Sadly there is nothing helpful in the logs that I can see.
Thanks in advance!
docker-compose.yml file:
version: "3.9"
db:
image: mariadb:10.11
restart: unless-stopped
MYSQL_DATABASE: "passbolt"
MYSQL_USER: "passbolt"
MYSQL_PASSWORD: "P4ssb0lt"
app:
image: passbolt/passbolt:latest
depends_on:
- db
APP_FULL_BASE_URL: https://passbolt.domain.com
PASSBOLT_PLUGINS_SMTP_SETTINGS_SECURITY_SSL_VERIFY_PEER: "false"
PASSBOLT_PLUGINS_SMTP_SETTINGS_SECURITY_SSL_VERIFY_PEER_NAME: "false"
PASSBOLT_PLUGINS_SMTP_SETTINGS_SECURITY_SSL_ALLOW_SELF_SIGNED: "true"
EMAIL_DEFAULT_FROM: "passbolt@domain.com"
EMAIL_TRANSPORT_DEFAULT_HOST: "mail.domain.com"
EMAIL_TRANSPORT_DEFAULT_PORT: "465"
EMAIL_TRANSPORT_DEFAULT_USERNAME: "passbolt@domain.com"
EMAIL_TRANSPORT_DEFAULT_PASSWORD: "password123"
EMAIL_TRANSPORT_DEFAULT_TLS: "false"
DEBUG: "true"
command:
"/usr/bin/wait-for.sh",
"-t",
"0",
"db:3306",
"/docker-entrypoint.sh",
# - 80:80
- 10443:443
# - 80:8080
# - 10443:4433
database_volume:
gpg_volume:
jwt_volume:
Output of healthcheck:
www-data@0c4e537c1923:/usr/share/php/passbolt$ ./bin/cake passbolt healthcheck
Healthcheck shell.....
[PASS] PHP version 8.2.20.
[FAIL] Debug mode is on.
[HELP] Set debug to false in /etc/passbolt/passbolt.php
[PASS] Full base url is set to https://passbolt.silentmecha.co.za
SMTP settings
[WARN] SSL certification validation for SMTP server is disabled.
[HELP] You can try:
[HELP] you can try:
[PASS] Using latest passbolt version (4.9.0).
[PASS] 31 tables found.
[FAIL] 10 error(s) found. Hang in there!
Output of send_test_mail:
www-data@0c4e537c1923:/usr/share/php/passbolt$ ./bin/cake passbolt send_test_email -r user@domain.com
Debug email shell
Email configuration
Host: mail.domain.com
Port: 465
Username: passbolt@domain.com
Password: *********
TLS: false
Sending email from: Passbolt <passbolt@domain.com>
Sending email to: user@domain.com
Trace
Error: SMTP timeout.
