] I have read intro post: About the Installation Issues category
] I have read the tutorials, help and searched for similar issues
] I provide relevant information about my server (component names and versions, etc.)
] I provide a copy of my logs and healthcheck
] I describe the steps I have taken to trouble shoot the problem
] I describe the steps on how to reproduce the issue
OS: AlmaLinux 9.3 (Shamrock Pampas Cat) x86_64
Docker Version: 26.1.0
Hi all,
I’ve been trying to get my Docker container up and running for a while. But I keep getting stumped with this issue when trying to create the admin user.
2024-04-30 11:36:23 error: [Cake\Database\Exception\MissingConnectionException] Connection to Mysql could not be established: SQLSTATE[HY000] [1045] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES) in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php on line 144
Caused by: [PDOException] SQLSTATE[HY000] [1045] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES) in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php on line 132
2024-04-30 11:36:23 error: Could not connect to Database.
I’ve looked everywhere for solutions to try, I found some peeps with similar issues, but nothing congruent to this error. I’ve tried starting from fresh (following the docs to the letter), with and without traefik, I’ve even watched a YT walkthrough to make sure there wasn’t anything obvious I was missing.
docker-compose.yaml:
version: "3.9"
db:
image: mariadb:10.11
restart: unless-stopped
MYSQL_DATABASE: "passbolt"
MYSQL_USER: "passbolt"
MYSQL_PASSWORD: "P4ssb0lt"
depends_on:
- db
APP_FULL_BASE_URL: https://pb.domain.com
EMAIL_DEFAULT_FROM: "passbolt@domain.com"
EMAIL_TRANSPORT_DEFAULT_HOST: "localhost"
EMAIL_TRANSPORT_DEFAULT_PORT: 25
EMAIL_TRANSPORT_DEFAULT_USERNAME: null
EMAIL_TRANSPORT_DEFAULT_PASSWORD: null
EMAIL_TRANSPORT_DEFAULT_TLS: null
command:
"/usr/bin/wait-for.sh",
"-t",
"0",
"db:3306",
"/docker-entrypoint.sh",
#ports:
# - 80:80
# - 443:443
# - 80:8080
# - 443:4433
labels:
traefik.enable: "true"
traefik.http.routers.passbolt-http.rule: "Host(`pb.domain.com`)"
traefik.http.routers.passbolt-https.rule: "Host(`pb.domain.com`)"
traefik:
image: traefik:2.6
restart: always
- 12480:80
- 12443:443
- ./conf/:/etc/traefik/conf
- ./shared/:/shared
database_volume:
gpg_volume:
jwt_volume:
Docker log:
2024-04-30 11:34:28+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.11.7+maria~ubu2204 started.
2024-04-30 11:34:28+00:00 [Warn] [Entrypoint]: /sys/fs/cgroup///memory.pressure not writable, functionality unavailable to MariaDB
2024-04-30 11:34:28+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
2024-04-30 11:34:29+00:00 [Note] [Entrypoint]: MariaDB upgrade (mariadb-upgrade or creating healthcheck users) required, but skipped due to $MARIADB_AUTO_UPGRADE setting
2024-04-30 11:34:29 0 [Note] Starting MariaDB 10.11.7-MariaDB-1:10.11.7+maria~ubu2204 source revision 87e13722a95af5d9378d990caf48cb6874439347 as process 1
2024-04-30 11:34:29 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2024-04-30 11:34:29 0 [Note] InnoDB: Number of transaction pools: 1
2024-04-30 11:34:29 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2024-04-30 11:34:29 0 [Note] mariadbd: O_TMPFILE is not supported on /tmp (disabling future attempts)
2024-04-30 11:34:29 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000MiB, chunk size = 2.000MiB
2024-04-30 11:34:29 0 [Note] InnoDB: Completed initialization of buffer pool
2024-04-30 11:34:29 0 [Note] InnoDB: File system buffers for log disabled (block size=512 bytes)
2024-04-30 11:34:29 0 [Note] InnoDB: End of log at LSN=1147328
2024-04-30 11:34:29 0 [Note] InnoDB: 128 rollback segments are active.
2024-04-30 11:34:29 0 [Note] InnoDB: Removed temporary tablespace data file: "./ibtmp1"
2024-04-30 11:34:29 0 [Note] InnoDB: Setting file './ibtmp1' size to 12.000MiB. Physically writing the file full; Please wait ...
2024-04-30 11:34:29 0 [Note] InnoDB: File './ibtmp1' size is now 12.000MiB.
2024-04-30 11:34:29 0 [Note] InnoDB: log sequence number 1147328; transaction id 1277
2024-04-30 11:34:29 0 [Note] Plugin 'FEEDBACK' is disabled.
2024-04-30 11:34:29 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
2024-04-30 11:34:29 0 [Warning] You need to use --log-bin to make --expire-logs-days or --binlog-expire-logs-seconds work.
2024-04-30 11:34:29 0 [Note] Server socket created on IP: '0.0.0.0'.
2024-04-30 11:34:29 0 [Note] Server socket created on IP: '::'.
2024-04-30 11:34:29 0 [Note] mariadbd: ready for connections.
Version: '10.11.7-MariaDB-1:10.11.7+maria~ubu2204' socket: '/run/mysqld/mysqld.sock' port: 3306 mariadb.org binary distribution
2024-04-30 11:34:29 0 [Note] InnoDB: Buffer pool(s) load completed at 240430 11:34:29
2024-04-30 11:34:29 3 [Warning] Aborted connection 3 to db: 'unconnected' user: 'unauthenticated' host: '172.19.0.4' (This connection closed normally without authentication)
2024-04-30 11:34:31 4 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:34:32 5 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:34:32 6 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:34:32 7 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:34:32 8 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:34:32 9 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:34:33 10 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:34:33 11 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:34:33 12 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:34:33 13 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:35:01 14 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:35:01 15 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:35:01 16 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:35:01 17 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:36:02 18 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:36:02 19 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:36:02 20 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:36:02 21 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:36:23 22 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:36:23 23 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:36:23 24 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:36:23 25 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:37:01 26 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:37:01 27 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:37:01 28 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:37:02 29 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:38:01 30 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:38:01 31 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
2024-04-30 11:38:01 32 [Warning] Access denied for user 'passbolt'@'172.19.0.4' (using password: YES)
Healthcheck:
[PASS] PHP version 8.2.7.
[PASS] Full base url is set to https://pb.domain.com
[HELP] cURL Error (6) Could not resolve host: pb.domain.com
[FAIL] The application is not able to connect to the database.
[HELP] Double check the host, database name, username and password in /etc/passbolt/passbolt.php.
[HELP] Make sure the database exists and is accessible for the given database user.
[FAIL] No table found
[HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake passbolt install" www-data
[HELP] sudo su -s /bin/bash -c "/usr/share/php/passbolt/bin/cake migrations migrate --no-lock" www-data
[HELP] you can try:
[FAIL] This installation is not up to date. Currently using 4.6.2 and it should be 4.7.0.
SMTP Settings
[FAIL] 11 error(s) found. Hang in there!
