[ X] I have read intro post: About the Installation Issues category
[ X] I have read the tutorials, help and searched for similar issues
[ X] I provide relevant information about my server
- Docker server
- RH8
- MySql database hosted on separated server
Hi everyone.
I am trying to install PassBolt in docker.
this is the compose file I’m using:
version: "3.9"
container_name: passbolt
restart: unless-stopped
APP_FULL_BASE_URL: https://192.168.1.20:10443/
#DATASOURCES_DEFAULT_URL: "SERVERNAME"
DATASOURCES_DEFAULT_HOST: "SERVERNAME"
DATASOURCES_DEFAULT_PASSWORD: "THEPASSWORD"
- /var/lib/docker/volumes/passbolt_volume/_data/gpg:/etc/passbolt/gpg
- /var/lib/docker/volumes/passbolt_volume/_data/jwt:/etc/passbolt/jwt
command:
"/usr/bin/wait-for.sh",
"-t",
"0",
"SERVERNAME:3306",
"/docker-entrypoint.sh",
- 1080:80
- 10443:443
I previously created the MYSQL user and an EMPTY DATABASE.
WHEN the container starts, it completes the DB creation and migration process, and the webpage for the login appears.
So, I suppose the DB connection is actually working.
I’m following the guide, and executing the command:
docker exec -it passbolt sh <-- to access the shell
su -l www-data -s /bin/bash <-- switch linux user
/usr/share/php/passbolt/bin/cake passbolt register_user -u xxx@xxxx.it -f xxxxx -l xxxxx -r admin
but this error appears:
2024-05-28 16:09:37 error: [Cake\Database\Exception\MissingConnectionException] Connection to Mysql could not be established: SQLSTATE[HY000] [2002] No such file or directory in /usr/share/php/passbolt/vendor/cakephp/cake php/src/Database/Driver.php on line 144
Caused by: [PDOException] SQLSTATE[HY000] [2002] No such file or directory in /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php on line 132
healthcheck:
www-data@087177e79445:~$ /usr/share/php/passbolt/bin/cake passbolt healthcheck
warning: 512 :: SplFileInfo::openFile(/var/lib/passbolt/tmp/cache/persistent/myapp_cake_core_translations.cake_console.en_UK): Failed to open stream: Permission denied on line 393 of /usr/share/php/passbolt/vendor/cakephp/cakephp/src/Cache/Engine/FileEngine.php
Healthcheck shell.........................................2024-05-28 16:26:20 error: [TypeError] strpos(): Argument #1 ($haystack) must be of type string, bool given in /usr/share/php/passbolt/src/Service/Healthcheck/Application/SslFullBaseUrlApplicationHealthcheck.php on line 39
