Docker connection to mariadb could not established
Hi, I try to install Passbolt CE using Docker following the steps described in the official documentation, but when I try to create first user, an error arise:
Host ‘172.23.0.3’ is not allowed to connect to this MariaDB server.
I have purged docker container and images many times, but nothing changed.
Thanks
Hello @gorneman , welcome to our community :slight_smile:
After you removed any sensitive information, could you share the docker-compose yaml file?
it was a test, so I only changed URL to localhost in docker-compose file.
  db:
    image: mariadb:10.11
    restart: unless-stopped
      MYSQL_DATABASE: "passbolt"
      MYSQL_USER: "passbolt"
      MYSQL_PASSWORD: "P4ssb0lt"
    depends_on:
      - db
      APP_FULL_BASE_URL: http://localhost
    command:
        "/usr/bin/wait-for.sh",
        "-t",
        "0",
        "db:3306",
        "/docker-entrypoint.sh",
      - 80:80
      - 443:443
    # - 80:8080
    # - 443:4433
  database_volume:
  gpg_volume:
  jwt_volume:
I’m also facing the same issue. Please let me know if you’ve found a solution for this problem. Thanks.
