Docker install issues
I’m trying to run a proof of concept before we consider deploying Passbolt.
I’ve followed the docker install for Passbolt but without pro which may the issue. I just pulled the latest docker pull passbolt/passbolt.
I cannot hit the web page but looking at the healthcheck I have DB issues and config files seem to be missing. When trying to set up the user I get:
Exception: SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘passbolt-db.users’ doesn’t exist in [/var/www/passbolt/vendor/cakephp/cakephp/src/Database/Schema/Collection.php, line 132]
When trying to install defaults:
su -s /bin/bash -c “/var/www/passbolt/bin/cake passbolt install” www-data
I get:
The GnuPG config for the server is not available or incomplete.
I copied the default config file to passbolt.php which then broke the healthcheck.
--------------HEALTHCHECK---------------
[PASS] PHP version 7.3.12.
[PASS] Full base url is set to https://ec2-35-178-186-15.eu-west-2.compute.amazonaws.com
[HELP] cURL Error (60) SSL certificate problem: self signed certificate
[PASS] 1 tables found
[HELP] sudo su -s /bin/bash -c “/var/www/passbolt/bin/cake passbolt install” www-data
[HELP] sudo su -s /bin/bash -c “/var/www/passbolt/bin/cake migrations migrate --no-lock” www-data
[PASS] Using latest passbolt version (2.12.0).
5 error(s) found. Hang in there!
Hi Mark,
Did you set DB parameters in the config file yet? Copying is not enough… Copy in order to use config.php with your own info.
Try install after that. Repeat the Healthcheck and report back if you get stuck.
Thanks I assumed database credentials would be populated from setting the environment variables from the docker run string.
docker run -d --name passbolt --net passbolt_network -p 443:443 -p 80:80
-e DATASOURCES_DEFAULT_HOST=172.18.0.2
-e DATASOURCES_DEFAULT_PASSWORD=password
-e DATASOURCES_DEFAULT_USERNAME=admin
-e DATASOURCES_DEFAULT_DATABASE=passbolt-db
-e APP_FULL_BASE_URL=https://ec2-3-10-206-215.eu-west-2.compute.amazonaws.com passbolt/passbolt:latest
I copied the passbolt.php.default to passbolt.php and populated the file with the DB values from the runstring above
I’m hitting a key issue on the healthcheck.
Healthcheck shell…Exception: Could not use key for signing. get_key failed in [/var/www/passbolt/src/Utility/OpenPGP/Backends/Gnupg.php, line 240]
Is there a guide on setting up keys for the free version? Or is there a working docker file for the free version rather than trying to use the pro version?
Thanks Mark
Maybe something like this will help: The public key cannot be used to encrypt and sign a message
Getting keys owned by the web server is sometimes tricky, but that’s the idea.
Thanks for the info but what I don’t get is that the health check passes the GPG section referencing the config/passbolt.php file which doesn’t actually exist. When I create that file and put the DB details in GPG then fails. So is the healthcheck wrong and that is just a default output or is the config somewhere else and when I create the passbolt.php file with the DB details it overwrites it? Is there GPG config elsewhere I need to grab and stick passbolt.php when I create it?
I’ll dig around and see what is happening. As far as docker containers go this isn’t easy to scale at the moment in a privileged production environment.
Thanks Mark
I reverted to the default GPG config in the passbolt.php file for testing as suggested.
I still cannot browse. Which of the following errors are relevant at this point?
Healthcheck shell…
[FAIL] Debug mode is on.
[PASS] Full base url is set to ://ec2-3-10-206-215.eu-west-2.compute.amazonaws
[HELP] cURL Error (28) Connection timed out after 30001 milliseconds
[HELP] See. //www.passbolt/help/tech/update
[FAIL] Do not use the default gpg key for the server
[HELP] See. https://www.passbolt/help/tech/install#toc_gpg
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c “gpg --home /home/www-data/.gnupg --import /var/www/passbolt/config//gpg/unsecure_private.key” www-data
[WARN] Registration is open to everyone.
[HELP] Or set passbolt.registration.public to false in config/passbolt.php.
9 error(s) found. Hang in there!
I think it should be set to:
'fullBaseUrl' => 'https://ec2-3-10-206-215.eu-west-2.compute.amazonaws.com'
It is a critical setting. Other settings depend on this one.
Apologies any .com or https missing is to get past the posting filter. Apparently we can only post one link per thread.
@Mark That restriction was forgotten, sorry about that. I would recommend starting from scratch again. You are okay using the Community Edition and not pro, and correct that environment variables are sufficient.
Since the problems were at first with the DB and not keys, and now with the keys and not DB, I think if we’re trying to get to a live first-time use then a clean start might be the quickest way, given your objectives.
https://help.passbolt.com/hosting/install/ce/docker.html
If the DB problems arise again, don’t change the config file in the passbolt container… We have to figure out what’s going on with your DB. The instructions for either a host DB or container DB are in the link above, including discussion regarding persistence after container restart.
When the install is successful, it will seem easy.
Thanks for your time. I’ve run a clean install on a standard micro red hat ec2 instance on AWS. I have the file showing all the commands if you have a method for me to send it to you?
I get to the step where I set up the first user. Personal details redacted.
[root@ip-172-31-44-201 ec2-user]# docker exec passbolt su -m -c “/var/www/passbolt/bin/cake passbolt register_user -u nane.surname@company.co.uk -f name -l surname -r admin” -s /bin/sh www-data
/ _
//./_//__/
The healthcheck is the same as the first one in the top of this thread.
Thanks Mark
See if this works?
Thanks Mark
change to
-e DATASOURCES_DEFAULT_HOST=mariadb
Still the same error unfortunately.
Thanks Mark
The DB table is being recognized. It’s ready to install. Reference the Database section in the Healthcheck results.
I’m in catch 22 again I was trying run the database commands but failing on keys. I disable the security config as per the instructions but that doesn’t help. I’m looking into the keys on the server. I don’t have gpg keys on the server ec2 uses an open source version. I may just create some gpg keys and import them.
Thanks Mark
I ultimately did the same thing.
Remember that whatever user creates the key, it goes into that users keyring by default. If you create using root, then it’s not readable by the web server. Getting keys squared away was what I got stuck on myself, for this reason.
Passbolt error logs are pretty good so make sure to include them along the way.
Gpg is needed by passbolt, and I ended up using the gpg documentation because I was not on a fresh server, and there were other apps using other keys as well. But, the passbolt installation docs in the “install from source” section are quite helpful so don’t miss those.
