Information about my server on VM
|Distributor ID:|Ubuntu|
|Description:|Ubuntu 18.04.2 LTS|
|Release:|18.04|
|Codename:|bionic|
nginx version: nginx/1.14.0
Mysql:
Server: MariaDB
Server version: 10.1.38-MariaDB-0ubuntu0.18.04.2 Ubuntu 18.04
Protocol version: 10
PHP 7.2.17
Passbolt version 2.10.0
Healcheck
// _,///.__/__//_/
[PASS] PHP version 7.2.17-0ubuntu0.18.04.1.
[PASS] Full base url is set to https://passbolt.local
[PASS] 26 tables found
[PASS] Using latest passbolt version (2.10.0).
[WARN] Registration is open to everyone.
[HELP] Or set passbolt.registration.public to false in config/passbolt.php.
Problem:
Previously when entering the web address I missed a GPG warning, but in the healcheck everything was correct, I read an article and reinstalled the web browser extension. Then it does not come back out, but I try to register a new account or recover the previously created administrator account and nothing. It does not send any mail, and that already I made a test mail and sends it to me correctly
(Congratulations!
If you receive this email, it means that your passbolt smtp configuration is working fine.).
I’m sorry, I do not speak English very well and I use the translator.
