I installed a fresh new ubuntu with the latest Server-ISO available at ubuntu dot com.
It’s Version 22.04.2 LTS.
I was able to download every file and as well had successfull installed all components and created the database user and password.
unlucky it say go to the ip-adress from the server and start configure it.
this does not work because it’s showing me the standard nginx screen but no passbolt installation.
with /install added it won’t work either.
I’m currently not a pro at Ubuntu but basics i can do.
If you need some more informations please ask me and provide some command for it.
Greetings,
WonderworldCraft
Actually i’m only having some passbolt.default.php and default.php but no passbolt.php.
Here are the pictures from default.php, I’ll wasn’t able to copy text out of the ssh.
I’ll think something gone wong at installation, because youre saying that i’m supposed to have some passbolt.php file.
By the way, I’m using some virtualised vm ware ubuntu server …
Here are the complete VM WARE Folder, Username and Passwort are “passbolt”.
I’m currently only try it out because I’m searching for some good solution for my passwords, what is bether then the current one. ZIP-File is downloadable here: 1.91 GB file on MEGA
I just checked the ISO package list again to make sure it didn’t include NGINX or Mariadb and it doesn’t. The reason I checked is because passbolt installs these in the process.
To start fresh and get rid of installed files you would want to:
I just installed Ubuntu22.04 minimized on Virtualbox 7 and was able to get to this point here:
I have Port Forwarding on VBOX set from local 127.0.0.1:8080 to remote 10.0.2.15:80.
I am accessing with a Windows machine and set 127.0.0.1 u22passbolt.local in my hosts file.
Yes, with deleting “default” it show’s me the installation process.
There was at the Folder /etc/nginx/sites-enabled some default and nginx-passbolt.conf.
