I’m testing whole Passbolt setup update in a test enviroment.
Prod is running Passbolt 3.5 with MySQL 5.6, PHP 7.3 and NGINX 1.20.1
We are a “Percona MySQL” shop so we did the update to Percona MySQL 8.0.36-28 without changing anything else and Passbolt showed everything but couldn’t make changes or create anything new.
I embarked in the PHP, NGINX and PASSBOLT update to see if it fixed the issue but now I’m facing ERROR 500
[root@passbolt-prep passbolt]# su -s /bin/bash -c "./bin/cake passbolt healthcheck" nginx
[PASS] PHP version 8.1.28.
[PASS] Full base url is set to https://passbolt-prep.ceibal.edu.uy
[HELP] Check that the domain name is correct in /var/www/passbolt/config/passbolt.php
[PASS] 31 tables found
[PASS] The public key file is defined in /var/www/passbolt/config/passbolt.php and readable.
[PASS] The private key file is defined in /var/www/passbolt/config/passbolt.php and readable.
[PASS] The server key fingerprint matches the one defined in /var/www/passbolt/config/passbolt.php.
[PASS] The server public key defined in the /var/www/passbolt/config/passbolt.php (or environment variables) is in the keyring.
[PASS] Using latest passbolt version (4.6.1).
[WARN] The deprecated self registration public setting was found in /var/www/passbolt/config/passbolt.php.
[HELP] You may remove the "passbolt.registration.public" setting.
[HELP] Or set passbolt.email.validate.mx to true in /var/www/passbolt/config/passbolt.php.
[PASS] The /var/www/passbolt/config/jwt/ directory is not writable.
SMTP Settings
[HELP] Or set passbolt.security.smtpSettings.endpointsDisabled to true in /var/www/passbolt/config/passbolt.php.
cli-error.log
2024-04-10 14:49:07 error: [PDOException] SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'groups Groups LEFT JOIN groups_users GroupsUsers ON Groups.id = GroupsUsers.grou' at line 1 in /var/www/passbolt/vendor/cakephp/cakephp/src/Database/Statement/MysqlStatement.php on line 39
2024-04-10 16:40:51 error: [PDOException] SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'groups Groups LEFT JOIN groups_users GroupsUsers ON Groups.id = GroupsUsers.grou' at line 1 in /var/www/passbolt/vendor/cakephp/cakephp/src/Database/Statement/MysqlStatement.php on line 39
2024-04-10 16:48:06 error: [PDOException] SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'groups Groups LEFT JOIN groups_users GroupsUsers ON Groups.id = GroupsUsers.grou' at line 1 in /var/www/passbolt/vendor/cakephp/cakephp/src/Database/Statement/MysqlStatement.php on line 39
Fixed permissions error so error.log doesn’t show anything new
error.log
2024-04-10 13:22:00 Warning: Warning (2): session_start(): Failed to read session data: files (path: ) in [/var/www/passbolt/vendor/cakephp/cakephp/src/Http/Session.php, line 355]
2024-04-10 13:22:00 Error: [RuntimeException] Could not start the session in /var/www/passbolt/vendor/cakephp/cakephp/src/Http/Session.php on line 356
Request URL: /healthcheck/status.json
Client IP: 127.0.0.1
[root@passbolt-prep passbolt]# su -s /bin/bash -c "./bin/cake passbolt cleanup" nginx
Cleanup shell (fix mode)
2024-04-10 17:01:52 error: [PDOException] SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'groups Groups LEFT JOIN groups_users GroupsUsers ON Groups.id = GroupsUsers.grou' at line 1 in /var/www/passbolt/vendor/cakephp/cakephp/src/Database/Statement/MysqlStatement.php on line 39
<!DOCTYPE html>
<html class="passbolt no-js no-passboltplugin version" lang="en">
<head>
<meta charset="utf-8">
<title>Passbolt | An Internal Error Has Occurred.</title>
/ ____/ /_/ (__ )__ ) /_/ / /_/ / / /_
Copyright (c) Passbolt SA (https://www.passbolt.com)
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU Affero General Public License as
published by the Free Software Foundation, either version 3 of the
License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Affero General Public License for more details.
You should have received a copy of the GNU Affero General Public License
along with this program. If not, see http://www.gnu.org/licenses/.
<meta name="description" content="Open source password manager for teams">
<meta name="keywords" content="Passbolt, password manager, online password manager, open source password manager">
<meta name="robots" content="noindex, nofollow">
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="shortcut icon" type="image/x-icon" href="https://passbolt-prep.ceibal.edu.uy/favicon.ico" />
<link rel="icon" href="https://passbolt-prep.ceibal.edu.uy/favicon_32.png" sizes="32x32" />
<link rel="icon" href="https://passbolt-prep.ceibal.edu.uy/favicon_57.png" sizes="57x57" />
<link rel="icon" href="https://passbolt-prep.ceibal.edu.uy/favicon_76.png" sizes="76x76" />
<link rel="icon" href="https://passbolt-prep.ceibal.edu.uy/favicon_96.png" sizes="96x96" />
<link rel="icon" href="https://passbolt-prep.ceibal.edu.uy/favicon_128.png" sizes="128x128" />
<link rel="icon" href="https://passbolt-prep.ceibal.edu.uy/favicon_192.png" sizes="192x192" />
<link rel="icon" href="https://passbolt-prep.ceibal.edu.uy/favicon_228.png" sizes="228x228" />
<base href="https://passbolt-prep.ceibal.edu.uy/">
<link rel="stylesheet" href="https://passbolt-prep.ceibal.edu.uy/css/themes/default/api_main.min.css?v=4.6.1"></head>
<body spellcheck="false">
<div id="container" class="error page error-500">
<!-- header navigation -->
<header>
<div class="header first ">
<nav>
<div class="top navigation primary">
<ul>
<li class="left"><a href="https://passbolt-prep.ceibal.edu.uy/"><span>home</span></a></li>
<li class="right"><a href="https://passbolt-prep.ceibal.edu.uy/auth/login"><span>login</span></a></li>
</ul>
</div>
</nav>
</div>
</header>
<div id="content">
<div class="grid">
<div class="row">
<h2>An Internal Error Has Occurred</h2>
<p class="error">
An Internal Error Has Occurred. </p>
</div>
</div>
</div>
</div>
<footer>
<div class="footer">
<ul class="footer-links">
<li><a href="https://www.passbolt.com/terms">Terms</a></li>
<li><a href="https://www.passbolt.com/credits">Credits</a></li>
<li id="version">
<a href="https://www.passbolt.com/credits" class="tooltip-left" data-tooltip="4.6.1">
<i class="fa fa-heart-o"></i>
<span class="visuallyhidden">Versions</span>
</a>
</li>
</ul>
</div>
</footer>
</div>
</body>
</html>
Could it be that Passbolt if just “incompatible” with Percona?
