Server operating system name and version
HW-Info: Raspberry Pi 3 Model B Rev 1.2
OS Version: Raspbian GNU/Linux 11 (bullseye)
Debian Version: 11.2
Kernel Version: Linux StaticPi 5.10.92-v7+
Database server name and version:
Ver 15.1 Distrib 10.5.12-MariaDB
Php version:
PHP 7.4.28 (cli)
Passbolt version:
latest (new Installation)
Healthcheck:
pi@StaticPi:~/Downloads $ sudo -H -u www-data bash -c "/usr/share/php/passbolt/bin/cake passbolt healthcheck"
Healthcheck shell.....Notice Error: Undefined index: message
In [/usr/share/php/passbolt/src/Utility/Healthchecks/DatabaseHealthchecks.php, line 72]
2022-03-16 09:36:31 Notice: Notice (8): Undefined index: message in [/usr/share/php/passbolt/src/Utility/Healthchecks/DatabaseHealthchecks.php, line 72]
Exception: Connection to Mysql could not be established: SQLSTATE[HY000] [1698] Access denied for user ''@'localhost'
In [/usr/share/php/passbolt/vendor/cakephp/cakephp/src/Database/Driver.php, line 140]
pi@StaticPi:~/Downloads $ sudo systemctl start nginx
Job for nginx.service failed because the control process exited with error code.
See "systemctl status nginx.service" and "journalctl -xe" for details.
pi@StaticPi:~/Downloads $ systemctl status nginx.service
â—Ź nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2022-03-16 10:36:20 CET; 3min 50s ago
Docs: man:nginx(8)
Process: 4471 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 4472 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=1/FAILURE)
CPU: 262ms
Mär 16 10:36:18 StaticPi nginx[4472]: nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
Mär 16 10:36:18 StaticPi nginx[4472]: nginx: [emerg] bind() to [::]:80 failed (98: Address already in use)
Mär 16 10:36:19 StaticPi nginx[4472]: nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
Mär 16 10:36:19 StaticPi nginx[4472]: nginx: [emerg] bind() to [::]:80 failed (98: Address already in use)
Mär 16 10:36:20 StaticPi nginx[4472]: nginx: [emerg] still could not bind()
Mär 16 10:36:20 StaticPi systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE
Mär 16 10:36:20 StaticPi systemd[1]: nginx.service: Failed with result 'exit-code'.
Mär 16 10:36:20 StaticPi systemd[1]: Failed to start A high performance web server and a reverse proxy server.
pi@StaticPi:~/Downloads $ journalctl -xe
Mär 16 10:40:10 StaticPi sudo[7070]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:10 StaticPi sudo[7070]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:10 StaticPi sudo[7070]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:12 StaticPi sudo[7082]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:12 StaticPi sudo[7082]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:12 StaticPi sudo[7082]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:13 StaticPi sudo[7094]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:13 StaticPi sudo[7094]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:13 StaticPi sudo[7094]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:14 StaticPi sudo[7106]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:14 StaticPi sudo[7106]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:14 StaticPi sudo[7106]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:15 StaticPi sudo[7118]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:15 StaticPi sudo[7118]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:15 StaticPi sudo[7118]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:16 StaticPi sudo[7130]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:16 StaticPi sudo[7130]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:16 StaticPi sudo[7130]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:17 StaticPi sudo[7142]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:17 StaticPi sudo[7142]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:17 StaticPi sudo[7142]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:19 StaticPi sudo[7154]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:19 StaticPi sudo[7154]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:19 StaticPi sudo[7154]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:20 StaticPi sudo[7166]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:20 StaticPi sudo[7166]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:20 StaticPi sudo[7166]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:21 StaticPi sudo[7178]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:21 StaticPi sudo[7178]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:21 StaticPi sudo[7178]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:22 StaticPi sudo[7190]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:22 StaticPi sudo[7190]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:22 StaticPi sudo[7190]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:23 StaticPi sudo[7203]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:23 StaticPi sudo[7203]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:23 StaticPi sudo[7203]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:24 StaticPi sudo[7215]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:24 StaticPi sudo[7215]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:24 StaticPi sudo[7215]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:25 StaticPi sudo[7227]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:25 StaticPi sudo[7227]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:25 StaticPi sudo[7227]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:27 StaticPi sudo[7239]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:27 StaticPi sudo[7239]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:27 StaticPi sudo[7239]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:28 StaticPi sudo[7251]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:28 StaticPi sudo[7251]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:28 StaticPi sudo[7251]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:29 StaticPi sudo[7263]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:29 StaticPi sudo[7263]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:29 StaticPi sudo[7263]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:30 StaticPi sudo[7275]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:30 StaticPi sudo[7275]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:30 StaticPi sudo[7275]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:31 StaticPi sudo[7287]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:31 StaticPi sudo[7287]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:31 StaticPi sudo[7287]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:32 StaticPi sudo[7299]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:32 StaticPi sudo[7299]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:33 StaticPi sudo[7299]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:34 StaticPi sudo[7311]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:34 StaticPi sudo[7311]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:34 StaticPi sudo[7311]: pam_unix(sudo:session): session closed for user root
Mär 16 10:40:35 StaticPi sudo[7323]: www-data : PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Mär 16 10:40:35 StaticPi sudo[7323]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=33)
Mär 16 10:40:35 StaticPi sudo[7323]: pam_unix(sudo:session): session closed for user root
lines 981-1046/1046 (END)
– What steps did you take?
I did an new installation of Passbolt on my Raspberry Pi on which is already Pi-Hole runnning. Therefore I can’t access the Passbolt configuration Site. Chapter 2 in the installation guide.
– What happened?
I end up on the Pi-Hole configuration site.
– What did you expect instead?
Passbolt configuration site.
So my Question:
Is it possible to use my already existing and running Raspberry Pi with Pi-Hole and Passbolt?
