Hello.
I used passbolt docker image version : passbolt/passbolt:2.7.1-debian and migrated 3 weeks ago to passbolt/passbolt:2.10.0-debian. Since then i do not receive any email from passbolt anymore. I tryed to figure out what was the problem, here is what i found out until now, any help would be greatly appreciated.
Tiggering Test mail → OK
When i run ./cake passbolt send_test_email --recipient=myemail@mydomain.com
It ends with “The message has been successfully sent!” and indeed i receive the message in my mailbox.
Manually triggering mail → OK
When i run su -c "./bin/cake passbolt register_user -u myuser@mydomain.com -f Firstname -l Lastname -r admin" -s /bin/bash www-data
It ends OK as well and i receive the mail in my mailbox
Triggering mail through passbolt website → NOPE
If i complete the account recovery form and validate it the website says everything is ok and that i will receive email to complet recovery but nothing comes even after a loooong time.
Email queue
When i run :
SELECT id,subject,sent,locked,send_tries,send_at,created,config FROM email_queue;after validating the recovery form, no new record can be found, the last record found in this table is older than my migration to version 2.10 -
When i run
./cake EmailQueue.senderto send emails in queue, everything seems find, no error, no output at all -
When i run
./cake EmailQueue.previewto see queue content, i got the following error :
PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 20480 bytes) in /var/www/passbolt/vendor/lorenzo/cakephp-email-queue/src/Database/Type/SerializeType.php on line 22
2019-08-05 09:53:09 Error: Fatal Error (1): Allowed memory size of 134217728 bytes exhausted (tried to allocate 20480 bytes) in [/var/www/passbolt/vendor/lorenzo/cakephp-email-queue/src/Database/Type/SerializeType.php, line 22]
Fatal Error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 20480 bytes) in [/var/www/passbolt/vendor/lorenzo/cakephp-email-queue/src/Database/Type/SerializeType.php, line 22]
Cron
My root crontab is as follow
* * * * * su -c "source /etc/environment ; /var/www/passbolt/bin/cake EmailQueue.sender" -s /bin/bash www-data >> /var/log/cron.log 2>&1
When i run this command manually as root, i get no output neither to stdout, nor to /var/log/cron.log
HealthCheck result
[PASS] PHP version 7.2.18.
[PASS] Full base url is set to https://passbolt.mios.maxicoffee.domains
[PASS] 23 tables found
[HELP] sudo su -s /bin/bash -c "gpg --list-keys --fingerprint --home /home/www-data/.gnupg" www-data | grep -i -B 2 'SERVER_KEY_EMAIL'
[HELP] you can try:
[HELP] sudo su -s /bin/bash -c "gpg --home /home/www-data/.gnupg --import /var/www/passbolt/config/gpg/serverkey_private.asc" www-data
[PASS] Using latest passbolt version (2.10.0).
6 error(s) found. Hang in there!
Analysis
I know my healthcheck is not perfect, my SSL certificate is self signated and GPG conf is not perfect but it use to works like a charm and those errors are most probably not related. To me the mail config is ok, the cron trigger is ok but nothing feeds the mail queue and i have no errors in log.
Any idea where to dig ?
