Passbolt version: 3.6.0
Passbolt extension: 3.6.0
Browser: Chrome Version 102.0.5005.115 (Official Build) (arm64) (also Firefox)
OS: Mac OS X 12.2.1
Server: Apache
PHP Version: 7.4
Following the update to 3.6.0 from 2.13.5 (from source code), the extension is no longer detected.
Healthchecks are all green:
// _,///./_//__/
[PASS] PHP version 7.4.30.
[PASS] Full base url is set to https://password.martel-innovate.com
[PASS] 27 tables found
[PASS] The environment variable GNUPGHOME is set to /home/leonepr/.gnupg.
[PASS] The directory /home/leonepr/.gnupg containing the keyring is writable by the webserver user.
[PASS] Using latest passbolt version (3.6.0).
[PASS] The /home/leonepr/www/password.martel-innovate.com/config/jwt/ directory is not writable.
