Hello! Our organization has been using Passbolt since 2018 and it has been awesome. We’re now very dependent on it, so we decided to embark on making our Passbolt instance more resilient and provide an extremely high uptime to our users.
I’ve moved the database to three servers in different datacenters managed by Scalegrid.io, this is working awesome and the price was right. They are set up as master+slave+quorum node. Scalegrid manages the DNS entry so if the slave is promoted to master, it auto-updates the DNS entry.
For the application server, we have two ngnix servers running in separate datacenters, with a Cloudflare load balancer running in front of it to monitor health by checking each application server’s /healthcheck/status.json output and looking for the response body to contain:
“message”:“OK”,“url”:"/healthcheck/status.json",“code”:200},“body”:“OK”}
Questions:
- Anything else I should consider here?
- Healthcheck in the web UI reports one error:
The temporary directory and its content are not writable, or are executable.
Healthcheck via SSH/cake does not report this error. It does report an SSL Cert error, but that is just because NGINX is using a Cloudflare origin CA cert, I think.
./cake passbolt healthcheck
____ __ ____ / __ \____ _____ ____/ /_ ____ / / /_
// _,///./_//__/Open source password manager for teams
[PASS] PHP version 7.4.3.
[PASS] Mbstring extension is installed.Config files
[PASS] The passbolt config file is presentCore config
[PASS] Full base url is set to https://passbolt.milestonefe.com
[PASS] /healthcheck/status is reachable.SSL Certificate
[HELP] cURL Error (60) SSL certificate problem: unable to get local issuer certificateDatabase
[PASS] 27 tables found
[PASS] The database schema up to date.GPG Configuration
[PASS] The server private key format is Gopengpg compatible.Application configuration
[PASS] Using latest passbolt version (3.5.0).
[PASS] All email notifications will be sent.JWT Authentication
[PASS] A valid JWT key pair was found[FAIL] 2 error(s) found. Hang in there!
Both servers are running Ubuntu 20.04.
